Old 14-11-2005, 01:20 PM   #1 (permalink)
Kalyan's Avatar
Default slow clock
hi friends!!!
thnx for hlping me a lot. hope i get some answer
my clock on windows taskbar runs slower than the usual time. i get it slow by minutes. i had this problem since i bought my pc. i thought that the cmos battery might be expired or getting to, and i replaced it with a new battery. i still have a slower clock. though not as older times but it is slowing at the rate of one minute or so per day. how could i restore this? i am using an ASUS A7V266-MX hosting an AMD Athlon XP 2400+ processor and the pheonix bios. :roll:
Kalyan is offline
Old 14-11-2005, 03:09 PM   #2 (permalink)
alib_i's Avatar
Electronic clocks dont work that way .. low battery doesnt slow them down.
I think your motherboard clock's oscillator (or whtever it's called) is faulty..
That's why you have the problem since you bought it.
I think you should contact your vendor.
alibi
-Metallica
alib_i is offline
Old 15-11-2005, 06:22 PM   #3 (permalink)
Ask to the Asus ppl, in any case they have the support center at LamingtonRoad, Mumbai
mangemayur is offline
