Old 13-11-2005, 12:18 AM   #1 (permalink)
shariq_pj's Avatar
Default RAM Info please...
Hi guys...
I have ans asus p5gl-tmx mobo...
I installed this PC wizard software from Digit DVD and the specs u c below is that of the RAM...
Can u guys tell me the technical aspects of this info...?
Most importantly, the max freq speed of RAM my mobo suppports...
Help me guys...
General Information :
A0 (RAS 0) : 256 (Single Bank) -
A1 : Empty
A2 : Empty
A3 : Empty
Memory Controller Information :
Memory Controller : System Memory
Error Correction Capability : No
Number of connectors : 4
Max. Module Size : 4194304 KB
Chipset Information :
Type : DDR-SDRAM PC2100
Frequency : 133 MHz
FSB/RAM Multiplier : 1/1x
Channels : Single
ECC Diagnostic : No
CAS Latency (tCL) : 3 clocks
RAS to CAS (tRCD) : 3 clocks
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 8 clocks
Shared Memory (video) : Yes
Information SPD EEPROM (A0) :
Manufacturer : Smart Modular
Part Number : SM256MB400DDRBP6I
Serial Number : 10A80B00
Type : DDR-SDRAM PC3200 (200 MHz)
Size : 256 MB (1 rows, 4 banks)
Module Buffered : No
Module Registered : No
Width : 64-bit
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 2.5v
Supported Frequencies : 133 MHz, 166 MHz, 200 MHz
CAS Latency (tCL) : 2 clocks @133 MHz, 2.5 clocks @166 MHz, 3 clocks @200 MHz
RAS to CAS (tRCD) : 2 clocks @133 MHz, 3 clocks @166 MHz, 3 clocks @200 MHz
RAS Precharge (tRP) : 2 clocks @133 MHz, 3 clocks @166 MHz, 3 clocks @200 MHz
Cycle Time (tRAS) : 6 clocks @133 MHz, 7 clocks @166 MHz, 8 clocks @200 MHz
shariq_pj is offline
Old 13-11-2005, 01:26 AM   #2 (permalink)
Hey what you got there is all technical! What more technical do you want?? :roll:
Anyway you might've figured out that your mobo 256MB DDR RAM. The RAM does not support hardware based error correction control (ECC) and that
RAS = Row Access Strobe
CAS = Column Access Strobe
These are digital signals used to enable RAM modules and read data in words. The tCD and co. refer to timing. It's best you get hold of an engineering text and look at signal timing and clock skew.
Width refers to the number of bits that can be read simultaneously (parellely). The FSB speed is 133MHz and the RAM speed 200MHz. Since it's SD RAM, it has to be refreshed. The refresh speed is also given.
If you want a line by line explanantion, then you'd better get hold of an engineering text on memory. [/quote]
LordDJ is offline
Old 13-11-2005, 01:29 AM   #3 (permalink)
choudang's Avatar
what will be the size in GB = 4 GB
your mobo supported 256/333/400 MGz
choudang is offline
Old 13-11-2005, 09:13 AM   #4 (permalink)
shariq_pj's Avatar
Did'nt u meant DDRAM LordDJ...?
Anyways... I want to increase the RAM... Which brand and what speed are recommended....?
Old 13-11-2005, 06:43 PM   #5 (permalink)
Kingston and transcend are good, u may now get 400Mhz only (i think) but ur RAM will run at 200MHz only so no probs
Shwetanshu Srivastava
shwetanshu is offline
