sugest a good nforce chipset motherboard and amd chipset
i want a good nforce chipset motherboard with sata 2 support and amd 3500 939 pin support and ddr2 support. Maximum feature the better. SLI would be added advantage
can u guys please give me some details to start my search on it. budget for board is 15 k
Passwords are like underwear... Change them often...
ok guyz i am also facing the same confusion .. i am buying a amd 3000+ 939 pin procc and have the following choices for the mobo ,
1. ASUS A8N-E - Rs.6,000/- (all inclusive)
2. DFI LANPARTY UT nF4 Ultra-D - Rs.9600/- (all inclusive)
Now plz advice for which mobo from the abve should i go for ?? ..The dfi looks amazing n its considered the best for gamers but the price is way too high. Is it worth going for the dfi ????
Location: formerly black mesa resarch center,now city 17,india
@mohit dfi is xtremely optimised for gamers and ppl who overclock.if u are an EXTREME gamer(every fps counts) or ocer go for dfi.otherwise a a8ne should suffice.also consider ecs kn1 extreme.i heard its pretty good.
I\'ll give u my rigs config once u give me the rig!
Great choice! Bieng an AMD user for 4 years, I've seen many chipsets. But nothing beats nVIDIA. There's 1 place you should look for and that is this month's issue. Good enough stuff. Though they come @ a price. There's new entry by ASRock(with nForce 4 chipset) in a economy class which holds all of your prayers. ASRock 939NF4G-SATA2 is the answer for Socket 939. The best thing is it has the best IGP till date as it hold pixel shader 3.0. For the rest......you can play around. Good Luck.
