Old 10-11-2005, 11:57 PM   #1 (permalink)
Default need more serial ports
i need more serial ports to connect my external modem then , pctv remote reciever , how is this possible...i have
my mother board is intel D845GVSR ...please help
eureca_eureca is offline
Old 11-11-2005, 12:03 AM   #2 (permalink)
Rubik's Uncle!!
Charan's Avatar
u can use a usb to serial convertor kit/cable. i have heard or seen about that once in a ad. make sure the kit requires any drivers or not.You may also search for a serial port PCI card in the market.
Charan is online now
Old 11-11-2005, 12:24 AM   #3 (permalink)
Laptoping
Sourabh's Avatar
Getting a Simple USB to Serial converter would be cheaper and quiet easy to get. Search in ebay.in for the same. Since you require only a single Serial port, PCI cards with multiple serial ports would be rather useless.
Sourabh is offline
Old 11-11-2005, 12:25 PM   #4 (permalink)
Thx soubrabh and charangk
i think i can now go for a usb to serial convertor !
that must be cheaper than any other.
www.LiveGlamour.com
Old 15-11-2005, 06:30 PM   #5 (permalink)
u can also get the addon cards (i think they are called as magic card)
mangemayur is offline
Old 12-06-2009, 06:58 PM   #6 (permalink)
Default Re: need more serial ports
Thanks for your answer.I can't tell that I'm a begginer in Java but that code seems to me is coming from nowhere.
Can you please add more comments on the code?
SerialPortEventListener is an interface that comes with jdk1.2.2 or you wrote it?
What type is "myPort"?..is SerialPort?
This SerialPort datatype exists already in the packages from Sun or not?
What is tempData?...a byte?
Let me tell what I understood (and please tell if I'm right or not)
You have an interface called SerialPortEventListener
This interface has a method called serialEvent and you implement it.
You create a object of type SerialPort (e.g. myPort)
Then add the serial port listener to this object.
Please answer me..is very important for me because serial port reading (in Java)is one of the problems I have doing my college degree project.
us marriage
us marriage is offline
Old 12-06-2009, 07:19 PM   #7 (permalink)
rosemolr's Avatar
people say that usb to serial kit is not reliable..don't know how far it is true..
Extreme Mobile Professional..Ask anything about it..
Provide you all applications in symbian java uiq platforms
**THERE IS NO SPOON***
rosemolr is offline
