Old 27-10-2005, 06:21 PM   #1 (permalink)
kunwar's Avatar
Default Upgrading my Pc 2 make it run like Bugatti Veyron
As, i have many options in motherboards 4 my AMD 3200+(Socket939)
So,suggest me the BEST
1)Asus A8 nSli Premium (My friend says that going 4 SLI mobo will be FUTUREPROOF, Also,awarded as top performing in PC Quest ,oCT,05)
2)MSI RS 480 M2 (It has integrated gfx)
3)ECS KNI extreme (CHIP called it EXTREME value in their Sept issue)
4)FoxConn Winfast NF4UK8AA-8EKRS (Rs 4,950) [recommended by www.zdnetindia.com
5)Asus A8ne (Recommended by my friend -Sorabh)
i am also buying 66600 gt Golden Sample(only1) Rs. 8900
512 mb ram
Samsung Syncmaster 793s (Rs 5650)
i PROBLEM- AMD mobos doesn't support DDR2
Also,
will it be good decision to go 4 amd 3200 which works at only 2.0 GHz.
Or
I should i go 4 intel 3.0 GHz
1 G.B RAM , 6600 Non-GT , AMD 3000+ Processor
kunwar is offline
Old 27-10-2005, 08:23 PM   #2 (permalink)
harish_21_10's Avatar
Default Re: Upgrading my Pc 2 make it run like Bugatti Veyron
I dont think its worth getting an SLI board unless u get atleast a 6800gt card.
Since u have already decided to get a 6600gt card then why take this board?Here are few topics: http://www.thinkdigit.com/forum/view...light=clockgen
C**P might have given it the extreme value,but have you compared it with other boards?dont go only with what the magazines say.
Got no idea about this board
If u dont need integrated graphics then this is the board to go for
NOTE:There is no onboard VGA so a graphic card is compulsary.
or
If i am not wrong u want the PC for gaming as u are taking a 6600gt so i would recomend AMD over Intel.Also heat and noise level of AMD are lower than Intel.And 3200+ can easily be overclocked if needed.
This is what i had to say but also wait for others advice,but AMD is what most people will advice you.
harish_21_10 is offline
Old 27-10-2005, 08:52 PM   #3 (permalink)
Thinking that an SLI mobo will make you FUTUREPROOF is stupid. Unless you're buying 2 gfx cards now to get the max performance SLI is not worth it. People don't realize that by the time they would feel the need for another gfx card, one new x15xx series card alone (definitely available for less compared to the cost of your 2 gfx cards) could beat the s_hit out of an SLI 6600gt setup. Besides, there is no guarantee that 6600gt would even be available then. So my recommendation would be to go for a non-SLI board (save some money). When you finally feel the need for another gfx card, put your old 6600gt on ebay and buy a new x15xx or whatever series available at that time.
Your friend Sorabh's choice is a good one, Asus A8NE is one of the best nF4 implementations out there. I'd recommend DFI Lanparty nF4 Ultra-D - an overclocker's dream. Even if you are not into overclocking, buy it so that you have the option to do so when you feel like it. Not sure about its availability in India though.
Get atleast 1GB RAM and to your question about the processor choice, AMD is the way to go. Yes, AMD boards don't support DDR2 yet but that doesn't mean they are inferior in any way. In fact, it's a difference of implementation. You can think about it like this: your AMD 3200+ 2GHz would outperform Intel 3GHz any given time. Rite now, that's what is happening with DDR and DDR2. Don't wanna go into much technical details for reasons you prolly know but DDR2 have higher latencies resulting in a performance decrease. Although, that's changing rapidly now with faster chips coming into the market (not in India yet). Hope the processor analogy made sense to you.
geekysage is offline
Old 27-10-2005, 08:59 PM   #4 (permalink)
replied
http://www.thinkdigit.com/forum/viewtopic.php?t=31277
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 27-10-2005, 09:02 PM   #5 (permalink)
Originally Posted by blade_runner
Cool, good suggestions.
Old 28-10-2005, 10:07 PM   #6 (permalink)
My suggestion !!!
Hey how long will u Run ur system for ????
Hey FUTURE PROOF is all B**Ls !!!
And DIGIT and Chip keep talking about it !!!
Nothing is Future proof NOW - A - Days !!!
Wats ur Budget !!!
Since ur talking about 2.0ghz !!!!
Go in for the 3700+ on the 754 socket !!!
Which is the higest !!!
(Since u never said nething about buying 2 RAM Modules im asuming 1 = 512 mb ram module)
Which does not make sense !!!
Coz if u would go in for the 939soc u would only see a difference if u go in for 2 modules and run them in DUAL-DDR mode !!! COz the 939soc have a double memory Controller whre as the 754soc has a single memory controller which makes the difference between them !!!
Im running the BEST BOARD available on the 754soc with a Athlon64 2800+ !!! And its FASSSSSSSSST !!!!
I did Win XP install in approx 12 n1/2 13mins !!!!
Keeping the FRESH install option in mind !!!!
That have to be done manually !!! That was by me !!! And i belive "Haste makes waste !!!".
According to me my next upgrade will only come once im sure the 3700+ is Gonna get outdated !!!
So i can Relax for the next 1 n 1/2 - 2 yrs !!! Coz AMD has no intention to discontinue the 754SOCKET !!!
INFACT they have plans of Pushing the speed higher !!!
BTW i have a ASUS K8N-E Deluxe !!!!
WHICH Has been Know to be a TOP RATED Board By ALMOST ALL TOP MAGZ in the world !!!
Not Forgetting TOMSHARDWARE.COM
Ne way i hope my suggestion help u make a GOOD decision !!!
Cheers !!!
Cya Take Care !!!
\"Live Life as it comes & Live it KINGSIZE\"
\"Learn From Yesterday,Live For Today & Hope For Tomorrow\".
Bye 4 Now - N_!_r_a_L
King_Niral is offline
Old 28-10-2005, 10:21 PM   #7 (permalink)
ahh excitement's getting the better of u
A64 3200 winnie + 512*2 KVR 2.5-3-3-6 2T + MSI K8N SLI platinum - Creative SB Live! 7.1 + Leadtek PX6600GT 550/1125 + 160 GB Seagate N.C.Q. + 320 GB WD + LG 17" CRT
3Dmark05 - 4008 3Dmark03 - 8,983
Ringwraith is offline
Old 28-10-2005, 11:40 PM   #8 (permalink)
Hey If u meant that for me !!!
Oh boy "I SEE (Not only hear) What i believe !!".
cheers !!!
Old 29-10-2005, 02:13 AM   #9 (permalink)
@King_Niral: dude, Ringwraith was prolly referring to your hundreds of exclamations (!) after every line. try and learn some netiquette.
peace.
Old 30-10-2005, 12:30 AM   #10 (permalink)
chill hey ok !
itz a habit man
k thanx 4 clearing it
Cya
Old 13-11-2005, 09:39 AM   #11 (permalink)
kunwar's Avatar
ya,
i read the review of asus a8 ne in Nov issue of DIGIT.
It had the highest score of "price index" in the comparison.
Great mobo!
SEE THE COMPARISON to know about "ECS KN1 Extreme"
it is great but a bit higher priced than ASUS A8 n-e
Nov issue of DIGIT
kunwar is offline
Old 13-11-2005, 09:54 AM   #12 (permalink)
kunwar's Avatar
FOLLOW THIS LINK 2 KNOW ABOUT " FoxConn Winfast NF4UK8AA-8EKRS (Rs 4,950)"
http://www.techtree.com/techtree/jsp...554&cat_id=556
kunwar is offline
Old 14-11-2005, 02:38 PM   #13 (permalink)
Default Today is Today
I think ASUS is good but I don't think you SLI right now. And don't make you PC too future proof, cause in the future new RAM standards and faster, multicore processors with new graphics interfaces are gonna show up and your motherboard will get outdated for sure. And you will have too upgrade it then anyway.
You better spend your money on a better heatsink and more RAM which will really give you better efficiency and speeds since you will be able to overclock you Processor to atleast 2.4 Ghz and may be 2.8Ghz if lucky. Athlon 64 3200+ ROCKS!!!
jagjitnatt is offline
- by kool
