View Poll Results: can you spend more that 50,000 on the pc of your dreams
yes 7 87.50%
no 1 12.50%
Voters: 8. You may not vote on this poll
Old 22-10-2005, 07:23 PM   #1 (permalink)
chacx's Avatar
Default what company assembled pc??
yo people
i want to buy a pc for playing games with superb graphics that ask for a lot of hardware specifications. eg. doom and nfs2.
please suggest me some company made pc.
or you could suggest me some improvement in a company made pc that is economical also.
budget is not a problem.
i can even spend around Rs.75000 to get the pc of my dreams with a 19 inch lcd moniter.
chacx is offline
Old 22-10-2005, 10:12 PM   #2 (permalink)
Laptoping
Sourabh's Avatar
There isnt much choice from the branded segment which suit your need, budget and suffice what you wanna do with the system. http://exfinity.in is the only one i know who target the same. If you are in some metros, you can get a very good rig assembled for gaming within 75k with a descent 17" LCD.
Sourabh is offline
Old 23-10-2005, 12:36 AM   #3 (permalink)
choudang's Avatar
i want to make my pc for profession and playing games with xcellent graphics that ask for a best of hardware specifications.
can you give me some company made pc. that gives all the things, that is economical also.
budget does not matter i just spend around Rs.55,000 to get the pc of my dreams with a 17'' LCD
choudang is offline
