Old 21-10-2005, 09:26 PM   #1 (permalink)
Default AMD vs INTEL
i want to bye a comp .
i m totaly confused which processor should i bye. i want fast computer .can
anybody tell me is what r good n bad points in amd
give mepoints in favour and against AMD
AMD 2800+, 3000+ &above ,intel3Ghz 3.6 HT
give prizing also
also suggest me config.
both in amd & intel
for gaming .i need a fast comp
deepblue32 is offline
Old 21-10-2005, 10:13 PM   #2 (permalink)
Learner
Kniwor's Avatar
budget...??
cant suggest u anything till we know budget
http://kniwor.wordpress.com/
Kniwor is offline
Old 22-10-2005, 12:28 AM   #3 (permalink)
 Macboy
goobimama's Avatar
Oh the famous Intel VS AMD War....
End result is what you want to do. If you want for gaming, then I think AMD is much superior. But if you want to look into multimedia such as Audio and Video, then Intel is better (with HT technology)...
I'm like a bird...
goobimama is offline
Old 22-10-2005, 01:45 AM   #4 (permalink)
Learner
Kniwor's Avatar
and if u want the lord of all cpu's...that should last for a while...
get AMD X2..4800+ or X2 opteron...
(please guys dont bore me suggesting this cpu is better than the above in this category and etc....)
Kniwor is offline
Old 22-10-2005, 09:33 AM   #5 (permalink)
Manchester United
abhijit_reddevil's Avatar
2-3 threads already running on precisely the same topic:
http://www.thinkdigit.com/forum/view...&highlight=amd
Coming to your answers, AMD's the best. Search the forums and you will get your replies.
abhijit_reddevil is offline
Old 22-10-2005, 09:49 AM   #6 (permalink)
Another Brick in the Wall
drgrudge's Avatar
http://www.thinkdigit.com/forum/view...ight=intel+amd
drgrudge is offline
