Old 19-10-2005, 08:17 PM   #1 (permalink)
Default Need help on buying external hard disk
Hi friends
I want to buy an USB hard disk that I can attach to my three computers—one in office, one at home, and one laptop—and work on the files in it wherever its attached. I have narrowed down my search to Seagate 40 GB hard disk costing Rs 4,000 which I will have to put in a casing (Chineses ones are available at Rs 500).
Does this selection makes sense? Is it at the right price? Will the Chinese casing harm the hard disk? What precautions do I need to take?
Thanks.
Rajesh Gajra
Bombay
rgajra is offline
Old 19-10-2005, 08:26 PM   #2 (permalink)
Learner
Kniwor's Avatar
Why is this Seagate 40Gb costing u 4000. the cost sud be around 2200.
These hard disks as far as i know are nothing special, just get any pata u like and put in these rs. 500 case..
that's it..
Kniwor is offline
Old 19-10-2005, 08:39 PM   #3 (permalink)
My mistake. Its costing Rs 3,500 and is more than the Rs 2,200 you mentioned because its a hard disk made for laptops. Its thin in size and less in weight.
What I want to know is whether such hard disks are reliable. I will be shuttling between my home and office carrying this hard disk. What are the chances of it getting affected, etc?
Thanks.
rgajra is offline
Old 20-10-2005, 06:40 PM   #4 (permalink)
Netjunkie's Avatar
Look at this. It may be of some help
http://www.thinkdigit.com/forum/viewtopic.php?t=27202
Netjunkie is offline
Old 20-10-2005, 08:48 PM   #5 (permalink)
Thanks.
Yes, notebook HD's are quite reliable and can take more bumps than desktop ones. Also, they need lesser power and hence the casings won't have separate and bulky power supply/adapter.
http://cgi.ebay.com.au/USB-2-0-Exter...QQcmdZViewItem
http://cgi.ebay.com.au/USB-2-0-2-5-S...QQcmdZViewItem
Just a couple of examples.
Keith
Keith Sebastian is offline
Old 20-10-2005, 11:41 PM   #6 (permalink)
Thanks netjunkie, that link was pretty useful.
Keith, I am glad you said that. It makes me comfortable to go ahead now.
- Rajesh
rgajra is offline
Old 17-10-2008, 07:59 PM   #7 (permalink)
Default Re: Need help on buying external hard disk
360GB - Rs.3000
pikachu is offline
Old 17-10-2008, 09:17 PM   #8 (permalink)
Point Blanc
do not dump in such an old thread
besides external HDD 360GB would be based on Power adaptor which is of not good use as a real external.
acewin is offline
