Old 19-10-2005, 11:13 AM   #1 (permalink)
Default Is Geforce6200 pcie card capable of playing F.E.A.R?
Can anyone please tell me if geforce 6200(256mb) pcie gfx is capable of playing all latest games like quake 4 and F.E.A.R in high settings?Please help me friends
p_d5010 is offline
Old 19-10-2005, 12:05 PM   #2 (permalink)
Definitely yes. At reduced resolutions and without eye candy. But if you want a decent gaming experience, your minimum should be a G6600GT.
Keith
Keith Sebastian is offline
Old 20-10-2005, 08:52 PM   #3 (permalink)
gxsaurav
Posts: n/a
FEAR is a real system hog, it won't play at playable settings, even at 800X600 with no soft shadow & AA/Anis
http://www.anandtech.com/video/showdoc.aspx?i=2575&p=7 go hear for FEAR Graphics benchmarks
Old 21-10-2005, 12:59 AM   #4 (permalink)
You will be able to play the game at lowest settings . So the gameplay wont be that much enjoyable .
\" I Do not like to repeat success , i like to move on to other things \"
mako_123 is offline
Old 23-10-2005, 12:13 AM   #5 (permalink)
deathvirus_me's Avatar
they'll run .. but not at high settings .... maybe at 800*600 , medium + high ......
deathvirus_me is offline
Old 23-10-2005, 08:51 AM   #6 (permalink)
sidewinder's Avatar
I've tried it... it manages only abt 25 fps at800*600 lowest settings...
At 640*480 it manages abt 30 fps pn my amd 64 2800
Remember every settings was turned to minimum
Bombina rocks
sidewinder is offline
Old 28-10-2005, 01:04 AM   #7 (permalink)
no man its very similar to fx5200 so you wont able play . to play fear you need atleast 6600 gt with 256 mb ram
job9434 is offline
