| Forum |
#1 (permalink) |
My PC works fine with cold booting, but when restarting / warm booting, it is giving error after displaying VGA card information like: Nvidia GE Force 8x AGP, model date, memory info: 64mB etc. Out of Frequency VF : 31.5 Khz HF: 39.0 HZ Operating Frequency VF: 30-54 Khz HF: 50-120 Hz Is motherboard problem? Any one can help me to get ride of this problem. Thanks in advance |
#2 (permalink) |
How is the error message displayed ? Is it a Windows, DOS or monitor OSD message ?
Are you sure the VF and HF figures are both 31MHz ? It looks as if VF = Vertical Frequency, usually 60Hz (not MHz) or higher, HF = Horizontal Frequency, usually 31KHz (not MHz) or higher. I can't be sure but it seems your display settings are out of the range that's compatible with your monitor. When you've successfully cold-booted your computer, go to display properties and set it to something standard and non-demanding like 800x600 and 60Hz, and see what happens. |
#3 (permalink) |
HI,
| Bookmarks |
| Thread Tools | |
| Display Modes | |
