Old 17-10-2005, 11:01 PM   #1 (permalink)
blackleopard92's Avatar
Default samsung DVD drive prob.
I had my system assembled recently.
The DVD drive SH-D162C was giving 0.48x speed in nero test.
I found that DMA wasn't enabled.It was runnig In PIO.
i tried to enable it but it was futile.
i tried deleting respective DMA controller but it didn' t work.
I checked BIOS but nothing was Disabled.
The strange thing was that when i configured as secondary to my
CD Drive, my Drive was also slowed to 6.25x!!!also DMA was disabled to.
But When I configured it as Secondary master, the CD drive worked fine!
The end result is that CD drive is faster than DVD!!!
Somebody please help.!!
blackleopard92 is offline
Old 24-10-2005, 10:19 PM   #2 (permalink)
Default Hardware Help (Samsung (writemaster) DVD/CD Writer
I also have a strange problem with my Samsung make DVD/CD Writer. Its a combo drive. It can read DVDs (any - Data or Movie) but when it comes to CDs, it reads/detects only installer CDs. It refuses to detect any data, audio or a video CD.
Points to note:
Its not the auto-play problem. I have checked it.
I have tried changing the data cable. Doesnt help.
Can anyone help ???
yogee_bee is offline
Old 25-10-2005, 02:14 AM   #3 (permalink)
desertwind's Avatar
Default Re: Hardware Help (Samsung (writemaster) DVD/CD Writer
Same problem here too. using a LG DVD drive.
Sometime you'll think you understand everything
...Then you'll regain consciousness
desertwind is offline
Old 26-10-2005, 01:38 PM   #4 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Points to note:
Can anyone help ???
Yup guys same problem here even thou im using the SAMSUNG CD DRIVE as well as a SAMSUNG CD-R/W (both giv same problems..)
It fails to detect even my game Cds.I hv to eject and again pop in the tray (sumtimes 2-3 times) and then atlast my CD gets detected.I aslo hv a SONY DVD ROM DRIVE wich works perfectly fine whether its DATA,VIDEO,AUDIO or GAME CD,it detects at one go...
Looks like no wonder to mention but SAMSUNG DRIVERS ( be it CD,DVD or even COMBO) they all $UCK big time....
This has been a HERIDUTARY PROBLEM with all SAMSUNG DRIVE family....lol..lol...
Yaa even changing the data cable doesnt work.....
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
ashu888ashu888 is offline
Old 28-10-2005, 10:51 AM   #5 (permalink)
Default :( :( :(
So we cant do anything with our drives, than just keeping it.
Guess, I will have to invest in a CD writer seperately now
Old 28-10-2005, 11:46 AM   #6 (permalink)
Well yes ur rite bro...infact even if u send the SAMSUNG faulty drive to the service center,they will charge u sum money but again the same problem will arise in a couple of months time....
Coz I gave my CD WRITER for a repair work and i face the same problems even after jus 2 months hv past since the repair work...
Please try to use ur drive till its last stage and if u hv already planned to buy a new one...then go for brands like SONY as they hv gr8 funtionality as well as gr8 performance (in the later stages aslo) of their life..
Cheers n e-peace....
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Old 05-01-2006, 11:30 PM   #7 (permalink)
you mean those centers can't fix the Drive.!
mine is in warranty!!
Old 06-01-2006, 02:50 PM   #8 (permalink)
Well, its not tat.I mean to say that there is no suety that ur {repaired} drive will work to its Optimum performance and speed.Sumtimes the service center ppl jus change the Laser and do a bit of cleaning and thats it..and wen u ask them that Will this Drive be perfectly OK? then the answer comes "Cant say Sir !" .....
Believe me guys these Samsung Drives suck and I will never recommend any one to buy Optical Drives from the Samsung fraternity... It $uck$ big time..
The only option is to either stay with ur Samsung drive and pray to god (everyday) tat it works fine (after ur warranty is over) or to change it and buy any other brands other than Samsung. Coz i myself hv a Sony DVD ROM (works gr8 !) along with CD ROM and CD Writer(jus praying and using it till its last death arrives.. :roll: ) from Samsung.
Cheers n e-peace...
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
