| Forum |
#1 (permalink) |
i want to buy an athlon xo 64 3000+ or 3200+ but the problem is that in delhi the venice core is not available which i believe is the best among the available cores. the available cores are newcastle barton and winchester so which one should i buy btw i would be using it for gaming and graphics editing pls post the contact details of the dealer if u know that he/she has the venice core |
#2 (permalink) |
if u ask me it depends on the OS u would be using.......... but i would suggest you should buy barton core.... that kind of wide variety of $hits is not available here in chandigarh.... we just get the newcastle core here.....
PS: hurray this is my 200th post!!
The name is Mario, "Mario Pant"! mario = avatar; pant = पतलून and i'm NOT some mountain KiD! |
#6 (permalink) | |
Learner
Do u have nothing more important to do than posting wrong information around, There is nothing like "Athlon xo 64" or even "Athlon XP 64" does not exist. Athlon XP's were made on barton core... and they are discontinued...you might get mobile processors though... "AMD Athlon 64" processors exist. as for the original question about cores, I'd like to correct gxsaurav for the wrong information he has given... San Diego is not there for 3000+ or 3200+, Newcastle is on 130nm die, winchester is on 90nm, same as venice, less heat, better overclocker, so winchester is superior core to newcastle. Also gxsaurav, i do not mean any offense but will u please point me to where did u gather that information that newcastle is better than winchester. Let me post here the order in which the cores are better San Diego Venice Winchester Newcastle Clahammer Now I think ur question is pointless becuse u should easily get venice in delhi, if u dont i'll tell u where to get, i've a friend there who can provide u. As far as Venice is concerned look for E6 revision if u can get, which is out in US, the part number will look something like ....BW, or BWBOX, But u might not get E6 revision.... so u can have E3 revision part number ...BP, or ...BPBOX. That's what i have.
http://kniwor.wordpress.com/ |
#8 (permalink) | |
Learner
I've a friend there who has this site running, maybe he'll get u venice, gimme a day or two and i'll provide u with more information, and believe me, that venice core is worth waiting for "Because it has improved memory controller, apart fom the SSE3 support that has been added", so it's worth waiting, i had to wait about 15 days to get venice core back when it was uncommon, it's common now.
#11 (permalink) |
Manchester United
Heck no, buddy!!! At Delta Peripherals, Chennai (www.deltapage.com), they are selling 3000+ Venice core for around Rs.7300.
#12 (permalink) | |
Learner
| Bookmarks |
| Thread Tools | |
| Display Modes | |
