Results 1 to 7 of 7
  1. #1
    Nokia 7110 to iPhone 5 club_pranay's Avatar
    Apr 2004
    Atlanta, GA
    Default Keyboard Keys - Brightness Control
    I have a Sony Vaio VGN series Laptop. Originally shipped with Windows 7 x64 Home Edition(OEM). It had Fn keys combination to control volume and brightness. A nice overlay would show up on the screen to show current levels
    Fn + F3: Volume Down
    Fn + F4: Volume Up
    Fn + F5: Brightness Down
    Fn + F6: Brightness Up
    Few months back, after a HDD failure I had to install Windows 7 professional(Retail). Now, even after installing all the Sony Vaio drivers, the brightness control is totally disabled. Volume control works but without any onscreen overlay.
    Latest Update: Recently I Purchased windows 8. Now the volume control has a different overlay(on the top left part) but brightness control is still not working.
    Any Ideas on how to fix this?
    Do a favor for a complete stranger today...
  2. #2
    Sony " VA" "IO" kARTechnology's Avatar
    May 2012
    I'm beside of my neibour's house, in my house, which is on Eath in Solar System in Milky Way Galaxy
    Default Re: Keyboard Keys - Brightness Control
    Quote Originally Posted by club_pranay View Post
    Fn + F4: Volume Up
    Are you able to change brightness from control panel?
    I had a vgn series laptop with vista and installed 7, it was very difficult for me to get fn keys working but I got it working and maybe I can help you
    GIGABYTE GA-MA78GM-S2HP | TRANSCEND DDR2 1GB MICRON DDR2 2GB | AMD Athlon 4600+ | CORSAIR CX430V2 | VIEWSONIC VA1918wm 19" LCD | NUMERIC 600 Ex-C UPS | INTEX 2000Watt 2.1 SPEAKERS | LOGITECH Media Keyboard | PIONEER VSX-916 | MISSION SATELLITES | DAINTY SUBWOOFER | AIRTEL HD DTH| SONY BRAVIA BX300 | VAIO VGN-CS17G | SONY ERICSSON XPERIA X10 | CYBERSHOT T70 | PLAYSTATION 2 | HANDYCAM DCR-TRV460E
  3. #3
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Install keyboard hotkey driver. It should b included in the driver bundle. Or download it from product's official page.
  4. #4
    Battle Ready Shashank Joshi's Avatar
    Nov 2012
    India
    Quote Originally Posted by d6bmg View Post
    .. You can even try from the battery settings option..
    Only The Dead Have Seen The End Of War!!
  5. #5
    Apr 2004
    Atlanta, GA
    Quote Originally Posted by kARTechnology View Post
    Yes. I can control the brightness through settings. Let me know what you did. I appreciate your help.
    I particularly installed the VAIO® Event Service and its subsequent updates from the driver's page. nothing helped
    I am going to try this tutorial (http://blog.komeil.com/2009/07/fn-f5...sony-vaio.html) i'll update if it helped.
    Thanks guys
  6. #6
    Aug 2011
    Kolkata
    Then you may try to reinstall them and see what happens.
  7. #7
    Apr 2004
    Atlanta, GA
    I did it.
    Problem Solved!!
    Here's what i did.
    Key is to install these in the EXACT order.
    1. Sony Firmware Extension Parser Device Driver (SODOTH)
    2. Sony Shared Library (SOASSL)
    3. Setting Utility Series (SOASUS)/VAIO Event Service (SOAVES)
    Here's what Sony eSupport website says on the Sony® Notebook Utilities download page:
    Sony® Shared Library: Unless stated otherwise, this file must be installed BEFORE the Sony® Notebook Utilities in order for it to work properly. This update is required if you have performed a clean install of the Windows 7 operating system (i.e., installed from a commercial, off-the-shelf, version rather than using the Recovery Wizard or Recovery Media).
    Thanks guys
