Results 1 to 6 of 6
Thread: desktop refusing to boot
16-11-2012, 04:41 PM #1Broken In
- Join Date
- Apr 2011
- Posts
- 130
hi everyone. today afternoon, while playing some songs, my pc got stuck (the same sound tone played briefly) and it stopped working. when i press the power button, the MoBo LEDs light up, the MoBo fans start, but the fan at the back of the cabby (connected to a fan power slot on the MoBo) does not start and also there is no display. seems like it's not getting into BIOS. i have tried changing the GPU, RAM, removed the CMOS battery, pulled out and plugged in the power cords on the MoBo, but no luck! any idea what might have gone wrong?
C2D E8400 | 4GB DDR2 (800MHz) | 320GB + 500GB + 1TB |XFX 680i LT MoBoGigabyte G41M Combo | Sapphire HD7850 2GB DDR5 | Logitech MX518 | CM Silent Pro M700 | Corsair 400R | APC 1.1 KVA
24-11-2012, 05:09 PM #2
Re: desktop refusing to boot
I Think I have doubt in your PSU . According to your signature , it is a Cooler Master One . It may have Blown .
Intel Core I5 2400 | Intel DH67CL B3 | Corsair Value Select 2x 4 GB | Seagate Barracuda 500 GB HDD | Asus DVD RW | CM Elite 310 | Corsair GS600 | Logitech MK200 | Creative Speakers | Samsung S20B300 | V Guard UPS | Intel HD 2000 | Nokia Lumia 520 |
26-11-2012, 10:52 AM #3In The Zone
- Join Date
- Apr 2012
- Location
- london
- Posts
- 208
If its not the psu than there are very mush chances that your mobo is burnt.
Regards
Frank
http://www.testchief.com/
27-11-2012, 12:52 AM #4
how many ram sticks?
is the pc stuck in a loop? (like, is there any pattern to the fan's speed? slow-fast-slow-fast?)
if you have multiple ram sticks, plug them in one by one, in different slots. borrow some ram sticks from someone and recheck.Mmmphh-mphhhh-mmphh mhh!!!
27-11-2012, 03:59 AM #5
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
27-11-2012, 04:55 AM #6
to add on what TopGear said, Silent Pro psu series is not the regular CM crap. it is their top end line. i'd willingly put one in my PC, if i could find one within my budget.
for CM, best stay away from eXtreme power and GX series. not very trustworthy, and barely better than the local iball, zebronics psu. (tho GX series is ok)
silent pro and real power are the only 2 products of their psu range you should really buy.
anyway, if the psu had died, then nothing would have worked. this is why we here at digit INSIST on putting high quality psu's in our rigs (think of it as a bullet proof vest. sure, it costs $$$$, but it saves your life which is >>>> ($/0) )Mmmphh-mphhhh-mmphh mhh!!!
LinkBack URL
About LinkBacks
