Results 1 to 18 of 18
  1. #1
    Apprentice sanny16's Avatar
    Jul 2012
    Navi Mumbai
    Smile HDMI cable for connecting monitor to cpu?
    Can a motherboard have HDMI port? If yes then can i use it to connect cpu and monitor using hdmi cable? The monitor will have hdmi port(led 22''). Will be better than vga connection?
  2. #2
    Alpha Geek avinandan012's Avatar
    Jul 2010
    hyderabad
    Default Re: HDMI cable for connecting monitor to cpu?
    Quote Originally Posted by sanny16 View Post
    HDMI is basically DVI + Audio
    steam : chery012
    garena : avinandan012
    Audio Equipment: Edifier C2
    Android : Galaxy Grand
  3. #3
    Nov 2011
    NCR
    VGA is analogue(old & originally meant for crt monitors),DVI & HDMI are digital(meant for modern displays which are digital).
    Is God willing to prevent evil, but not able? Then he is not omnipotent.
    Is he able, but not willing? Then he is malevolent.
    Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
  4. #4
    Jul 2012
    Navi Mumbai
    which all motherboards have hdmi and dvi?
  5. #5
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Almost all the motherboards, made of a iGPU supporting chipset, would have HDMI port at the back.
    Exception: very few.
  6. #6
    Jul 2012
    Navi Mumbai
    what does one look for when purchasing a motherboard? How important is the cache memory of a processor? Buying a 10,000 rpm hdd advisable?
  7. #7
    Aug 2011
    Kolkata
    10K rpm HDD?
    Which one?
    Need more info about your requirement.
    The most important thing to which you should look for while buying a motherboard is your budget.
  8. #8
    Jul 2012
    Navi Mumbai
    WD black 1 tb HDD 10000 rpm at around Rs.7,500. How important is the rpm factor of an internal hdd from gaming perspective? How much difference is there between HDMI connection and VGI connection in terms of visual quality? 18 inch LED monitor is sufficient for gaming?
  9. #9
    Alpha Geek sharang.d's Avatar
    May 2012
    Pune
    I would recommend at least 22 inches for gaming.
    Yes HDMI/DVI/DP Vs. VGA(D-Sub) gives a hell lot of noticable difference.
    Intel Core i5-2500k ASUS P8Z77-V PRO CM Hyper 212 EVO G.Skill 1600Mhz 4G X 2 Sapphire HD 7870 Seasonic S12II 620W Corsair Carbide 400R Microsoft Sidewinder X6 Logitech G400 LG E2381VR Razer Goliathus Control Edition (Small)
    Additional Cabinet Fans CM Blue LED silent fan 140mm Silverstone AP121 120mm
  10. #10
    Wise Old Owl Nerevarine's Avatar
    Feb 2011
    Bhubaneshwar, Orissa, India
    ^^ Are you certain of this ?? I am using Dell In2030M and have used both DVI and VGA but havent found even a slight difference
    My Speedtest results
    i3 2120|Transcend 4GB DDR3|ASUS P8H61 M LX|ASUS DRW5ST DVD RW|Corsair VS450|Zebronics Ronak Cabinet|Dell IN2030M|Phillips SHP1900|Seagate Barracuda 250GB + WD Scorpio Blue 160 GB + Iomega external HDD 500 GB|Dell Wireless Mouse/KB combo|Intex Protector 600va UPS| ASUS HD 7770
    Life's a glitch, deal with it :P
  11. #11
    May 2012
    Pune
    Yeah I tried D-Sub and HDMI cables on a friends 25+ inch bravia. Had noticeable difference!
  12. #12
    Jul 2012
    Navi Mumbai
    I connected my laptop to 40 inch sony LED via HDMI cable but did not notice any difference there. HDMI cable supports both audio and video? I am using HDMI cable of prolink, purchased from flipkart.
  13. #13
    Jul 2012
    Navi Mumbai
    Can anyone help in enabling the HDMI output sound in my led tv?? I am able to see the visuals but nothing is audible. I have googled for this problem but no solution could fix the sound problem.
  14. #14
    Aug 2011
    Kolkata
    There must be a HDMI output port in your TV.
  15. #15
    Mar 2005
    @sanny16 - Have you set the audio playback output device to HDMI in the sound properties on your pc/laptop?
  16. #16
    Broken In baiju's Avatar
    Sep 2006
    Kerala
    Set HDMI as the default playback devices by right clicking the task bar volume control icon. Sometimes you will also need to change the sound device to hdmi in your media player.
  17. #17
    Aug 2011
    Kolkata
    Bumping in an one month old thread?
  18. #18
    Jul 2012
    Navi Mumbai
    Yes there are 4 HDMI port in the led tv and the tv automatically takes hdmi output as default once you enter in the HDMI option. I have googled on this topic but nowhere it is mentioned to disable other speakers in the speaker option. When i played a song i could see the fluctuation in bar graph which is beside the hdmi ouput audio option which means that the hdmi audio is enabled and also it is set default(rite clik on sound icon from task bar then select playback option). Here you will see more then one speaker, all of them enabled so the TV gets confused and hence could not play the sound. Disable every other speaker except the HDMI audio output.
Tags for this Thread
