Results 1 to 2 of 2
  1. #1
    Dec 2011
    kalyan
    Exclamation urgent!!! problem with intel dot station
    Hi there,
    one my friend gave me a Intel Dot Station computer.
    when i first power on it shows intel celeron image
    after then i got stuck with the language
    I clearly didnt understand is it spanish or sumthing else
    wont be able to move further.
    if possible tell me how to format that intel dot station
    and 1thing is that keyboard came with that pc is not having any del/f2 button.
    u can check screenshots attached
    2012-08-28 20.20.49.jpg2012-08-28 20.21.09.jpg2012-08-28 20.21.37.jpg2012-08-28 20.22.03.jpg2012-08-28 20.22.23.jpg2012-08-28 20.22.34.jpg2012-08-28 20.23.17.jpg2012-08-28 20.23.28.jpg2012-08-28 20.23.59.jpg
    thnks in advance
  2. #2
    Aug 2012
    Default Re: urgent!!! problem with intel dot station
    i have used this PC before.
    first of all, the round keys on top also work as function keys, i know. try using some combination. there's a special key for that i guess.
    1. what OS is it?
    2. to format, you'll have to use external USB drive. try using bootable flash drive if it supports. if it doesnt support flash drive booting, you'll have to manage an external cd rom. no other option.
