Results 1 to 13 of 13
25-08-2012, 07:08 PM #1Broken In
- Join Date
- Jul 2011
- Posts
- 124
Motherboard Stopped accepting RAM more than 256mb
hi guys.. suddenly my motherboard has stopped accepting
ram more than 256mb. whenever i am putting 1gb ram it
starts beeping continuously and not booting. i have checked
my ram in another system its ok, i have also checked my
ram ports both are working fine with 256mb ram. Please help
my config is
intel p4 (HT)
Intel origional GC101 motherboard
abacus zion 1 gb and 256 mb ram
25-08-2012, 08:54 PM #2Point Blanc
- Join Date
- Jan 2008
- Posts
- 1,890
Re: Motherboard Stopped accepting RAM more than 256mb
DDR2 DDR what is he RAM, P4 support DDR and not DDR2, hence upgrading RAM wille a prob. Also older mobos not all will support 1 GB RAM sticks. run cpu-z to get the info about mobo make and try to put the info here.
do a google for CPU-z it is very simple app
26-08-2012, 01:11 AM #3Broken In
- Join Date
- Jul 2011
- Posts
- 124
It is DDR ram it was working quite well. But suddenly it stopped working, on same mother board and same ram.
26-08-2012, 01:18 AM #4
Try inserting it into another machine to see if it works there. If is does not work out there, then you might have a faulty RAM stick. Also, try inserting it into another RAM slot to see if the slot is faulty.
26-08-2012, 01:42 AM #5
Possibly BIOS limitation. You can't do much about it.
Inactive in TDF.
26-08-2012, 01:59 AM #6Broken In
- Join Date
- Jul 2011
- Posts
- 124
I tried in another system it's working fine. My both Ports of motherboard are ok as 256 mb ram is running in both Ports. 1 month back it was working properly so i don't think it's a bios limitation
26-08-2012, 02:03 AM #7
26-08-2012, 07:51 AM #8Broken In
- Join Date
- Jul 2011
- Posts
- 124
I think it's time to leave my six year old baby and go for a new pc. I am opening new thread. Thank you very much guys and please help me there to but new one.
26-08-2012, 12:51 PM #9Little Kid
- Join Date
- Aug 2012
- Location
- Kolkata
- Posts
- 572
Did you flash the BIOS ??
If not first reset it with jumper and then use the Intel Flasher to flash and update it with a new BIOS ROM..
You may download the latest BIOS and Flashing tools from here, http://downloadcenter.intel.com/defa...+dnlds_driversSpoiler:
26-08-2012, 08:16 PM #10Broken In
- Join Date
- Jul 2011
- Posts
- 124
I have also updated bios
no luck there.
26-08-2012, 10:34 PM #11
Ok, then it looks like memory controller problem. Sadly, you can't do much about it.
Inactive in TDF.
27-08-2012, 05:50 AM #12
Time to go for a new config.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
29-08-2012, 10:01 AM #13Broken In
- Join Date
- Jul 2011
- Posts
- 124
I have opened a new thread for suggestions.
Please help me there. and thanks for your support guys.
Link
LinkBack URL
About LinkBacks
