Results 1 to 19 of 19
  1. #1
    True Manchester City fan sam9953's Avatar
    Mar 2012
    Delhi
    Default Safely Removal Hardware reads SD card but not showing in My Computer
    Hi guys, when I put in my micro SD card along with my SD card adapter, my laptop is gives the "sound" when a new hardware is attached but nothing shows up in My Computer, though it shows the option for removal from Safely Removal Hardware.
    What can I do?
    Up For Sale:
    Hindi and English Movies and Audio CDs for Sale (dirt cheap)
    Free Printer refill INK (black) for giveaway, half bottle.
  2. #2
    msn
    msn is offline
    खिड़की माने Windows msn's Avatar
    May 2010
    Bangalore
    Default Re: Safely Removal Hardware reads SD card but not showing in My Computer
    Check card - reader driver if its there. Uninstall and re-install the card reader driver and then try again.
    My RIG - Phenom II X6 1055T | GA-785 GMT-USB3 | ATI Radeon HD4200 | Coolermaster Xtreme Power Plus 600W | Transcend DDR3 2048MB | 500GB Seagate
    Canon 1100D | 18-55 IS Lens | Lowepro | Marumi | Hoya
    ____________________________________
    Follow me | Write on my wall | My Blog
  3. #3
    Mar 2012
    Delhi
    Quote Originally Posted by msn View Post
    Yes, in my laptop I found a driver folder and it has Card reader folder which had the setup of Realtek PCIE card reader, I have removed it and then re installed it. But still no difference. Is this the right driver, you think?
    I can't find any other folder for the driver of my SD card reader.
    Up For Sale:
  4. #4
    msn
    msn is offline
    May 2010
    Bangalore
    If you have any additional card then try using that to check if that gets detected.
  5. #5
    sam
    sam is online now
    Forum Moderator sam's Avatar
    Jan 2010
    Guwahati
    PCIE expansion card i guess. And no software is required for memory card. check windows update. something maybe missing from the lappy.
  6. #6
    Sage of the Six Paths
    Sep 2011
    Is the card ok? Maybe the card reader is dead.
  7. #7
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Not only you I sometimes also face the same problem with my Internal card reader. When I insert any card, sometimes it shows up and sometimes it is not.
    I'm yet find a solution for this problem.
    P.S. This is not a card reader problem, but a problem related to device driver.
    Inactive in TDF.
  8. #8
    Mar 2012
    Delhi
    Yeah, i have done evrything. I am updating the windows constantly as well. I don't have any extra SD card or any SD card adapter. Any other solution?
    Up For Sale:
  9. #9
    msn
    msn is offline
    May 2010
    Bangalore
    If you have any live cd like Damn Small Linux or Hiren Boot CD, then boot into Live Environment and check if it shows up the card there or not.
  10. #10
    Mar 2012
    Delhi
    Sadly I don't have either of the two.
    Up For Sale:
  11. #11
    msn
    msn is offline
    May 2010
    Bangalore
    Hmm.... !!
    May be the adapter write protected !! Not sure though. Check to see if this helps
  12. #12
    Mar 2012
    Delhi
    Yes, I have found the problem. It is being read and it occupies one drive but it does not display the drive in my computer and it is "write protected". Now what should I do?
    Up For Sale:
  13. #13
    msn
    msn is offline
    May 2010
    Bangalore
    Unlock it. Click this link Memory card is write protected or locked
  14. #14
    Mar 2012
    Delhi
    I did try the things mentioned in the link but I don't get any option to format the drive because basically my computer does not read it as a readable disk, it just says like something is there, with 0mb storage.
    Up For Sale:
  15. #15
    sam
    sam is online now
    Jan 2010
    Guwahati
    HP USB Format tool. Google and download it.
  16. #16
    Aug 2011
    Kolkata
    Try to install realtek card reader driver.
    Inactive in TDF.
  17. #17
    Mar 2012
    Delhi
    Quote Originally Posted by d6bmg View Post
    It is already installed and came with my laptop. I have reinstalled it.
    Up For Sale:
  18. #18
    msn
    msn is offline
    May 2010
    Bangalore
    Follow these steps :
    1. Shutdown your computer or laptop
    2. Insert USB Memory Stick into your laptop or Computer
    3. Turn on laptop and then immediately start pressing (F8) key then Advanced Boot Options screen will come up
    4. Select Safe Mode with Command Prompt
    5. After loading files if your USB Memory Stick drive letter is (G) for example then write G: after C:\windows\system32>and press enter
    7. Then Type - format G: and press enter
    8. If ask you (Y/N) then press (Y) and press enter
    9. Now a full format will start which remove write protection from USB Memory Stick.
    Note: Make sure you double check your PenDrive Drive letter before executing the format command. I have used G: as an example.
  19. #19
    Mar 2012
    Delhi
    I tried your steps but it didn't work out. Thanks, I will go tomorrow to get this micro SD card checked.
    Up For Sale:
