Results 1 to 8 of 8
  1. #1
    Jun 2009
    Pune
    Default Lenovo y560 random color screen after bootup
    Hi, I have Lenovo y560 with switchable graphics laptop. from the last 2 days when i turn it on, it starts and in the middle of starting it's screen turns into various colors (only one color per boot). is it ram problem?. i already switches rams inside .also my lappy runs on adaptor no battery(it's faulty) can any one suggest where to look at? also it does not restart easily .
  2. #2
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Default Re: Lenovo y560 random color screen after bootup
    Most probabily
    either there is a problem with display screen
    or it is a problem of motherboard.
    Inactive in TDF.
  3. #3
    Jun 2009
    Pune
    Hi,
    the problem is gone and everything was working fine for last 4 days. i even tested memory on different memory slots using memtest86+ 4.20 using usb pen drive it worked fine for 7 passes each in line.swithed off only to change slots and ram. worked good for 4-6 days now it is starting and shutting down. can it be a motherboard problem ?
  4. #4
    Aug 2011
    Kolkata
    What do you mean by, "now it is starting and shutting down"?
    Random reboot?
    Inactive in TDF.
  5. #5
    Jun 2009
    Pune
    hi i had 20v 4.5 amp adapter after it broke my seller gave me a 19v 3.42 amp adapter can it be the culprit ? also what are the symptoms for bad charging circuit of battery?
  6. #6
    Aug 2011
    Kolkata
    ^^ IMO, you shouldn't use that adapter.
    Inactive in TDF.
  7. #7
    Jun 2009
    Pune
    i checked with monarch in pune they told me the laptop is dead. motherboard replacement cost 11000/- battery 5500/- and if i go for buy back i get 8000/- . got to a local chip repairing person. problem was with charging circuit being weak. Replaced it now working fine also told me adaptor of less capacity is fine as long as it does not heat and is original.
  8. #8
    Rubik's Uncle!! RCuber's Avatar
    Sep 2004
    ಬೆಂಗಳೂರು (Bengaluru)
    what was the cost of repair+parts?
    the cake is a lie
    621311.251521
