Results 31 to 53 of 53
31-07-2012, 10:30 PM #31
Re: Computer freezes in Chrome, not Explorer yet
Which Windows u are running??
and also is it 32 bit or 64 bit
31-07-2012, 10:33 PM #32
FAQ + answers for new members (Read before asking / messaging any moderator for any query)
Drop Box: Get 500MB free
31-07-2012, 10:36 PM #33Apprentice
- Join Date
- Feb 2011
- Posts
- 79
By now I have done lost of things. Is doing this better or doing a reinstall of OS better?
If I need to to a reinstall(never done earlier) what are the steps - I have the Windows CD and drivers CDs etc. But I have huge amountof files about 75 GB. My small pen drives cannot take them all. Is it safe to burn files on a DVD? Any suggestions.
Just preparing for the worst!
WIn 7 64 bit
31-07-2012, 10:45 PM #34
First tell the no of drives you have and which drive has windows installed in it. You may want to restore your system to a previous date.
31-07-2012, 10:51 PM #35Apprentice
- Join Date
- Feb 2011
- Posts
- 79
2 drives with the other one being larger. I had done a System Restore earlier but did not work.
How do I find out which one has Windows installed in it?
Other drive says 367 free of 368 GB
31-07-2012, 10:56 PM #36
Your c: is your windows drive
It's better if we can chat join here freenode Web IRC (qwebirc)
Choose nickname and channel as #krow
31-07-2012, 11:09 PM #37Apprentice
- Join Date
- Feb 2011
- Posts
- 79
Is it possible to reinstall OS and keep the other drive for storing files? Is the other drive unaffected by the reinstall?
Also, how much time does a reinstall take?
There's always a first time!
Let's stick to this thread. Some poor soul will get help from info here tomorrow if the same happens to someone
31-07-2012, 11:11 PM #38
It's possible to reinstall but you have to format the drive where windows is installed.
31-07-2012, 11:25 PM #39Apprentice
- Join Date
- Feb 2011
- Posts
- 79
Thanks!
For those reading the thread and can help here are some questions I have:
1. What are the steps in reinstalling OS on C drive? Any good links to articles or sites will also do(will search on Google also)
2. Can the other drive(I have 2 drives) be used to store files as a backup - is it safe to do so? Or should I burn DVDs or get a hard drive for storage?
3. Will the other drive be unaffected by OS reinstall on C drive?
4. Anyth other tips when I resinstall, out of your experience?
31-07-2012, 11:32 PM #40
Boot form windows DVD. Follow the steps. Choose C: when asked to select drive. Format it and then install the windows.
Yes, Second drive which is your D: can be used to take backup as it will not be formatted when installing windows.
Yes definitely other drives besides C: , are not affected by reinstall.
01-08-2012, 12:15 AM #41
My RIG - Phenom II X6 1055T | GA-785 GMT-USB3 | ATI Radeon HD4200 | Coolermaster Xtreme Power Plus 600W | Transcend DDR3 2048MB | 500GB Seagate
Canon 1100D | 18-55 IS Lens | Lowepro | Marumi | Hoya
____________________________________
Follow me | Write on my wall | My Blog
05-08-2012, 12:12 PM #42Apprentice
- Join Date
- Feb 2011
- Posts
- 79
Before I proceed I was having a doubt. If, as above, there is some fault with Hard Drive, will doing a reinstall solve the problem of freezing?
Alternatively, should I reinstall in the other drive that I have and not in the same drive as before?
How much time does a reinstal take - I will need to keep aside that much of timeLast edited by maxtor; 05-08-2012 at 04:47 PM.
05-08-2012, 10:45 PM #43
Windows takes about an hour to install. If you don't have a faulty HDD, then backup your data on the D: drive and format the C: drive, the D: drive will be untouched.
DELL Inspiron N5010; 4GB RAM; 300 GB HDD; 512 MB VRAM; ATI Mobility Radeon HD 5470; Windows 7 Ultimate
Me on FB, My Forum, Me on Steam, Me on Twitter
05-08-2012, 11:01 PM #44
Before re installing, type MSCONFIG in 'start', and goto startup tab and processes tab, then post the contents here (screenshot).
Also, I'd recommend trying a Linux (mint) live CD/pen drive, to rule out ram problem.
I'm on mobile, so can't post links/tutorial.
You can download it with a download manger or get it from digit magazine CD/DVD.
also try updating windows7. And try opera browser.★--------------�--------------★
ASUS K53SV SX520D + BF3
06-08-2012, 01:12 AM #45
I have a suggestion for you. Uninstall your Antivirus and Firewall. Try using Chrome again.
06-08-2012, 08:57 AM #46Apprentice
- Join Date
- Feb 2011
- Posts
- 79
I don't want to work w/o firewall and antivirus except as for some test that I can't put off - that too for maybe 2-3 mins.
06-08-2012, 06:43 PM #47
FYI, Windows firewall, is itself, good.
Inactive in TDF.
06-08-2012, 08:13 PM #48Apprentice
- Join Date
- Feb 2011
- Posts
- 79
Been doing a lot of troubleshooting in the last two days most of which given in the forum threads. I also searched for windows updates and downloaded and installed each one of the pending ones
Have disabled AVG in Chrome extensions.
Finally today from early part of the evening things seem to have normalised though it is too early to fully confirm. I have tried several tabs in Chrome and it seems to be ok now. If all is fine tomorrow also I will consider my issue solved
Thank you in advance for all your help. Let me confirm tomorrow.
06-08-2012, 08:29 PM #49
All the best maxtor!
09-08-2012, 06:51 PM #50Apprentice
- Join Date
- Feb 2011
- Posts
- 79
UPDATE:
Today the power unit stopped working. I have a Tacens Supero 500W Power Supply Unit.
It has been 1 month outside warranty so I took it for repair and when the guy opened the SMPU he said that the damage was being done for some time and that i should have brought it earlier. He also mentioned that it starts with the system hanging frequently. Took him about 30 minutes and it was fixed(charge - Rs 250)
Lessons learnt are as follows:
1.Gaming rigs like these cannot really handle Indian summers and it is best to place it in an AC room or in a similar cool environment(with extra cooling even an additional external fan)
2.All Windows updates should be up to date and never left pending
3.Regular scans and maintenance.
Also, a major cause of heat inside CPU esp in the Indian summer - The SMPU fan does not have an opening which pushes the hot air directly, the hot air is pushed downward and then pushed out by the additional fan as shown in the picture. It is a design fault and it can heat up the components in a computer especially in summer. Going ahead I will have to plan to have an external cooling system to keep it cool in summer when I am playing games etc.
Google Image Result for http://sabiosdelpc.net/review/tacens_supero_500/supero7.png
Hope my thread proves to be useful to someone who has an assembled system and who faces a similar problem.
09-08-2012, 07:21 PM #51
the bottom facing fan in the PSU sucks air & throws it from the back of PSU.
for heat management,
1. keep a minimum 6" distance between the back of cabinet & wall.
2. cable management inside the cabinet
3. clean the internals once in 2 months or so.
4. if experiencing high temps at idle, add a fan to the cabinet, a 120mm on the side.
If you dont have a UPS, then get one asap, & also check whether earthing is proper in your house/pc room.★--------------�--------------★
09-08-2012, 07:22 PM #52
1. Yes and no. You need a good cabinet along with good CPU cooler.
2. It is not related to freezing.
3. Depends on your internet browsing & downloading habit, if you know what I mean.
Inactive in TDF.
09-08-2012, 08:58 PM #53Apprentice
- Join Date
- Feb 2011
- Posts
- 79
There are total 3 fans as seen in the snap of my CPU including the power supply one which cannot be seen because it is facing downward .Do you mean a fourth fan? Where to fit it?
Good cabinet like which one? I have a Cooler Master that cost me 1.7k
computer freezes
By doomgiver in forum Hardware Q&AReplies: 10Last Post: 20-05-2011, 08:47 PM -
computer just freezes
By entrana in forum Software Q&AReplies: 7Last Post: 26-06-2008, 10:18 PM -
COMPUTER FREEZES after booting ?
By raja2281 in forum Hardware Q&AReplies: 7Last Post: 23-05-2008, 04:30 PM -
help my computer freezes
By gauravsuneja in forum Hardware Q&AReplies: 21Last Post: 31-12-2007, 07:48 AM -
Computer freezes!!!
By sudhix in forum Software Q&AReplies: 2Last Post: 04-01-2007, 11:22 PM
LinkBack URL
About LinkBacks
