Results 1 to 11 of 11
06-07-2012, 07:43 PM #1
How to Make This Micro SD Card Adapter Work?
Okay guys I have got a motorola micro SD card adapter, I tried to insert the adapter in my PC's SD card slot but it won't read the adapter, nothing comes up on my comuter, can you suggest me what could be the possible cause and do I need some driver or something for the adapter to be recognized by my computer?
Up For Sale:
Hindi and English Movies and Audio CDs for Sale (dirt cheap)
Free Printer refill INK (black) for giveaway, half bottle.
06-07-2012, 07:53 PM #2
Re: How to Make This Micro SD Card Adapter Work?
"Adapter" doens't need any driver. Most likely it's a bad adapter or something with your slot itself.
AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn)
| 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
06-07-2012, 11:09 PM #3
Yeah it seems to that might just be the case, is there any other method by which I can put data in my micro SD card apart from using the adapter because I think the SD card slot might have stopped working as my device is nearly 8 years old.
Up For Sale:
07-07-2012, 12:51 AM #4
Buy a USB/ internal card reader.
07-07-2012, 12:57 AM #5
which micro sd card are you using? .. dont tell me you are just using the adapter without the SD card....
the cake is a lie
621311.251521
07-07-2012, 10:40 AM #6
Up For Sale:
07-07-2012, 02:00 PM #7
Ok... It looks like a faulty adapter. Just use the adapter in some camera to check if it shows as storage. If it doesnt then the adapter has gone caput.
07-07-2012, 04:01 PM #8
thanks for the help
Up For Sale:
08-07-2012, 12:28 AM #9
14-07-2012, 03:13 PM #10In The Zone
- Join Date
- Apr 2012
- Location
- london
- Posts
- 208
some time due to virus card corrupted so did you check your card in some other device?????
Regards
Frank
http://www.testchief.com/
15-07-2012, 12:38 PM #11Banned
- Join Date
- Oct 2004
- Location
- Bangalore
- Posts
- 1,440
seems like you SD Card is having fault, check it by inserting it directly in your mobile phone or friend's mobile phone.
[Want to Buy] Nokia Micro usb cable and 16 gb micro sd card
By newway01 in forum Want to BuyReplies: 1Last Post: 26-04-2012, 11:16 AM -
micro sd card ????
By abhi615 in forum Mobiles and TabletsReplies: 6Last Post: 17-10-2011, 02:23 PM -
Which one from these Micro Sd card to buy ??
By saurabh kakkar in forum Buying AdviceReplies: 10Last Post: 30-10-2008, 04:05 PM -
how 2 make rca male to 2 rca female adapter ?
By sourav in forum QnA (read only)Replies: 3Last Post: 05-03-2008, 09:24 PM
LinkBack URL
About LinkBacks
