Results 1 to 30 of 40
Thread: RAM
04-07-2012, 08:34 AM #1Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
RAM
Hi I have currently intel core2duo e4400 2ghz cpu 1gb ram and 1gb nvidia 210 graphics card. I recently started using windows 7 from xp so wanted to upgrade ram. After installing another 1gb the monitor does not display anything though the comp starts. What could be the problem ? The comp starts with single ram, i even tried interchaging the ram in slots still problem persists. The PC is woring fine with 1 gb ram albit slowly. What should i do ?
04-07-2012, 10:03 AM #2
Re: RAM
have u tried running the system with using both RAM sticks, 1 stick at a time? This could possibly help you figuring out whether your RAM sticks are good or have gone kaput.
Maybe there's a problem with the RAM slot itself(if everything else is ok).I'm a KID in this BIG Cyber World!
Intel C2D E4500|CM Hyper TX3 EVO|Corsair VS450|MSI G41M-P26|Kingston VR 2 x 4GB DDR3 1333 MHz|Seagate 500 GB SATA 3.0+ WD 80 GB IDE|AOC E2243Fw2k|| Dell Inspiron 14R|Core i5 480M 2.66|WD 320GB SATA 3.0|6GB DDR3 1333|Philips SHP 2700|Microsoft Mobile 1000||Nokia C6-00
My Blog: http://www.metro-greens.in
04-07-2012, 11:03 AM #3Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
Ya tried running it with both sticks individually. Both are good. Also tried both slots.
04-07-2012, 11:18 AM #4
Re: RAM
RAMs are supposed to have incompatibility if not matched perfectly.
1. Are they both the same frequency?
2. Are they both from the same manufacturer?
3. There is some specification called timing or something.
Please check these. The symptoms you describe suggest incompatibility.Satyameva Jayate | Truth Alone Triumphs
AMDX2 3600+/3.5GB RAM/ASUS M2NPV-VM/Palit HD4670/160+320 HDD/DELL S2240L FullHD Monitor/PCLinuxOS 2012/WindowsXP Pro | Samsung NP305U1-A06IN
Nokia 6220c & E6 | Sony Ericsson Live With Walkman
04-07-2012, 11:38 AM #5
Re: RAM
^^sling shot, this doesnt matter. I used 2 diferent types of ram in my old pc, ie. 1 x 512mb 400mhz(transcend) + 1 x 2gb 800mhz(kingston)
PC+ Lumia 720 + iPod Touch 32GB + PSPSpoiler:
04-07-2012, 11:45 AM #6
Re: RAM
^ sling-shot's right. There might be some incompatibility. Check the RAM sticks individually using CPU-Z (Memory and SPD tabs). Even if the manufacturers aren't the same, the frequencies should match. RAM (CAS Latency) timings are not much of a hurdle unless you're using a high end overclocker's stick and another a somewhat value stick (you can also change the CAS Latency timings in BIOS in most motherboards.
@Siddharth_1: Strange! haven't heard of this. Possibly your mobo supports both DDR and DDR2 RAM's.I'm a KID in this BIG Cyber World!
04-07-2012, 12:05 PM #7Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
I had returned the new stick since it was not working. So i should check my present ram n buy another of same manufacturer and frequency ?
04-07-2012, 12:19 PM #8
Re: RAM
manufacturer doesn't matter a lot. check for the RAM type (DDR2 or DDR3) and frequency.
04-07-2012, 12:43 PM #9Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
Ok . I will check when i get home and reply. It isnt some problem of mobo or anything else? Sorry i am i a noob in hardware matters
04-07-2012, 01:36 PM #10
Re: RAM
HTC One V | Nokia 5233 | Nikon D3100 | Apple Ipod Touch 4G | Sound Magic PL21 | Sound Magic ES18
04-07-2012, 01:59 PM #11
Re: RAM
04-07-2012, 01:59 PM #12Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
No both the ram were working in both slots i tried all combinations but they were not working together.
04-07-2012, 02:50 PM #13
04-07-2012, 02:59 PM #14
Re: RAM
Seems to be a mismatched frequency problem
04-07-2012, 05:37 PM #15Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
Re: RAM
Ok i downloaded cpu-z my current ram is
ddr2
single channel
dram frequency 333mhz
cycle time 15 clocks
04-07-2012, 05:43 PM #16
Re: RAM
please post the cpu-z screen shots (Memory+SPD).
Seems to me like DDR2 667 Mhz (PC2-5300). Can't be sure unless cross checked with Max Bandwidth (which shows the Module Name and Frequency) under SPD tab of CPU-Z.Last edited by CyberKID; 04-07-2012 at 05:51 PM.
04-07-2012, 05:55 PM #17Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
Re: RAM
here are screenshots
How to upload photos ? lnik from dropbox not working ?. Here is direct link to the folder https://www.dropbox.com/sh/mhdjgp6qazpzsza/bZAYrcTG9aLast edited by Pranav19; 04-07-2012 at 06:06 PM.
04-07-2012, 06:07 PM #18
Re: RAM
^ use imgur.com
Confirmed! it's the PC2-5300. Try getting yourself a DDR-2 667 MHz stick. Alternatively to be on the safer side, try getting a stick from one of your friends if possible, to check before buying one.I'm a KID in this BIG Cyber World!
04-07-2012, 06:11 PM #19Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
Re: RAM
OK Thanks a lot.
04-07-2012, 06:12 PM #20
Re: RAM
Glad to be of help
04-07-2012, 08:59 PM #21Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
Re: RAM
Can you tell me how much RAM i can put 1GB or will 2 GB stick be compatible. other minor upgrade which can be done
also which one i should go for ?
http://www.flipkart.com/evm-ddr2-1-g...1-ef498ed8bef0
http://www.flipkart.com/transcend-dd...1-ef498ed8bef0
05-07-2012, 10:54 AM #22
05-07-2012, 11:14 AM #23
Re: RAM
But then how did 2 ram sticks of diff. frequencies(400 and 800mhz) sizes(512mb and 2gb) and from diff. manufacturers(ram from diff. manufacturers not working together makes no sense) worked fine i my pc???
05-07-2012, 11:20 AM #24
05-07-2012, 11:32 AM #25
Re: RAM
Instead of EVM (never heard of that!) go in for a Kingston one or stick to Transcend. Flipkart's got the 667 MHz Transcend sticks. Try comparing prices with that in the local market. I've found that Flipkart have prices about Rs. 100 or so higher than the local market. Better put in 2GB to be safe for atleast another year. Your system has a 32 bit OS, and 3GB will suffice. I think your system will support almost 8GB of RAM as your PC has an ATX mobo (as evident from the CPU-Z screenshots-your current RAM is in Slot #3)
Guys! lets not fight over different RAM's working together.
Timings doesn't matter a lot, until and unless you're an extreme overclocker. The RAM's are capable of operating at different frequencies way up till the maximum RAM frequency. The RAM sticks are required to operate at different CAS Latency timings as laid down in the specifications given by JEDEC (Joint Electron Devices Engineering Council), and the RAM sticks change their CAS timings according to their operating frequency.I'm a KID in this BIG Cyber World!
05-07-2012, 08:15 PM #26
Re: RAM
In an ideal world they should. But in the real world there have been many reports of problems related to these things. And the OP has already explained his situation.
So there is no harm in playing safe and getting exact matches.Satyameva Jayate | Truth Alone Triumphs
05-07-2012, 11:27 PM #27
Re: RAM
If there are more than one channel present in the board, RAM modules having different timing can be used. Otherwise, if two modules having different timings (not speed) is being used in a same channel, PC won't start at all.
06-07-2012, 12:11 AM #28Apprentice
- Join Date
- May 2012
- Location
- Pune
- Posts
- 76
What is timing of module ?
06-07-2012, 11:54 AM #29
Re: RAM
Memory timings - Wikipedia, the free encyclopedia should explain it to you better than anyone
06-07-2012, 01:01 PM #30
LinkBack URL
About LinkBacks
