Results 1 to 5 of 5
  1. #1
    Jun 2012
    Default Disable Intel HD 4000
    My new ASUS K55VM laptop now has a string of issues. The most important one being gaming.
    My system boasts of a nVidia 630M 2GB dedicated card but it still can't handle old games like mirror's edge or GTA 4. I have a 3rd gen Intel core and hence the Optimus feature of the Ivy Bridge that kicks in the dedicated graphics only when needed.
    Can I somehow disable this and make my dedicated card the default? As of now i dont think my card kicks in, even while playing GTA 4.
    The other issue is overheating. The computer shuts off itself due to the heat. I i\live in delhi and the mean temperature is about 38 here.
    What do i do? Should i contact the manufacturer?
  2. #2
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Default Re: Disable Intel HD 4000
    About overheating problem, I think, you should go for RMA.
  3. #3
    Super Geek kisame's Avatar
    Dec 2011
    Gwalior
    Quote Originally Posted by Ronnie View Post
    Intel HD cant be disabled.
    Contact the manufacturer since the its a defective piece.
  4. #4
    Human Spambot saswat23's Avatar
    Jan 2011
    Bhubaneswar
    Looks like a defective piece. BTW have you checked in BIOS for any options to disable Intel IGP.
    Check here
    My Blog :D
  5. #5
    geek........ Gauravs90's Avatar
    Sep 2008
    Meerut, India
    Go in NVIDIA control panel and manually set the program to use graphics card.
  1. headset below 4000
    By keepitgee in forum Audio
    Last Post: 31-07-2012, 05:28 PM
  2. merge intel HD 4000 + my old gpu??
    By amruth kiran in forum Graphic cards
    Last Post: 05-05-2012, 11:18 AM
  3. Need an lcd tft for rs 4000
    By hannibal2469 in forum TVs / Monitors
    Last Post: 12-10-2011, 11:07 PM
  4. Best phone below Rs.4000 ???
    By hari.vgl in forum Mobiles and Tablets
    Last Post: 21-05-2009, 09:29 AM
  5. agp within 4000
    By bkpeerless in forum QnA (read only)
    Last Post: 02-09-2006, 12:23 AM
