Results 1 to 4 of 4
Thread: TV Tuner question
13-06-2012, 10:16 AM #1Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
TV Tuner question
Hi,
Zebronics - TV tuners - External LCD* ZEB-L2012
I've want to buy this TV Tuner, since its an external one can I record shows on my computer from it?
Will I be able to connect my PS2 to my HD monitor using this TV Tuner?(Through the A/V input and output from D-Sub)
Any other better suggestions for a budget of 1.5K?
I need to buy this thing today, MOST IMPORTANTLY will I be able to connect by PS2 through the A/V ports on the TV Tuner and output through the D-Sub(monitor has it)? Will there be any lag? How good is UMAX?
13-06-2012, 12:33 PM #2Right Off the Assembly Line
- Join Date
- Oct 2009
- Posts
- 46
Re: TV Tuner question
You can get it but i think there might be a problem of lag while playing with your console.
13-06-2012, 11:42 PM #3Alpha Geek
- Join Date
- Nov 2007
- Location
- Bangalore
- Posts
- 702
My main purpose is to watch my Setup Box (or DTH) connection, DVD player and play PS2 on my HD monitor (Benq G2222HDL, has 1xDVI, 1xD-SUB), what do you suggest? (Without lag)
The STB, DVD and PS2 all have A/V outputs (Yellow, Red, White), I will obviously be using only one of them at a time.
14-06-2012, 12:02 AM #4
Why dont you get something from a better brand like AverMedia. This one: AverMedia AVerTV BOX GENIE 1 TV Tuner Card | Tv Tuner Card | Flipkart.com
I also have similar Zebronics LCD ext. TV tuner. Clarity is OK but i wish it had been better. Sound again is not that good.
And yes I am quite sure that you can connect your PS2 to your monitor via TV tuner. One of my friends who has a PS2 is actually connecting it to his Samsung monitor via his Enter TV Tuner.
TV Tuner and DTH
By GhorMaanas in forum Broadband and DTHReplies: 6Last Post: 18-11-2011, 12:41 PM -
Tv Tuner
By aryan24 in forum PC Components / ConfigurationsReplies: 1Last Post: 04-10-2011, 01:20 PM -
TV Tuner to buy with LCD?
By ANURAG SHARMA in forum Hardware Q&AReplies: 1Last Post: 22-06-2010, 05:10 PM -
tv tuner with lcd..???
By deepinder_mann1988 in forum TVs / MonitorsReplies: 1Last Post: 27-03-2007, 11:27 PM -
TV Tuner
By maharajadhiraj in forum QnA (read only)Replies: 1Last Post: 23-01-2006, 10:35 PM
LinkBack URL
About LinkBacks
