Results 1 to 4 of 4
  1. #1
    Alpha Geek anupam_pb's Avatar
    Dec 2008
    Durgapur
    Default Error message while booting
    Whenever my PC boots, the following error message displays up, then my PC turns off for about 5 sec, then restarts & boots to homescreen without any error message. But if I shut down the PC completely & then turn it ON, again the above mentioned things happens.
    Screenshot of Error message :
    What could the problem be ? This problem is there in my PC from last 1-2 weeks.
    Note: There is no problem in time & date displayed in my PC
    Desktop (@ home) :1st gen i3, 4GB DDR3 RAM, 500GB HDD, HD5670 1GB GDDR5 ;
    Laptop : Lenovo Ideapad Y500 (Intel Core i7 3632QM, 8GB DDR3 RAM, 1TB HDD, 2GB GDDR5 GT650M, 15.6"FullHD Display ) (Check My review for Y500's problems & its solutions) ;
    Samsung Galaxy S II(Omega v23 4.1.2)
  2. #2
    Gonna rock da whole world yashthedude's Avatar
    Jun 2012
    Nanded
    Smile Re: Error message while booting
    Our CMOS battery wich is on the motherboard is now dis-charged.
    For that thing you have to go to a computer hardware shop and buy one cmos battery and then replace it on your motherboard.
    Me Gusta !! :P
    Regards,
    Yash Patil
  3. #3
    Dec 2008
    Durgapur
    Default Re: Error message while booting
    But when there was problem with CMOS battery in my friend's PC, his system date & time were resetted at every startup....
  4. #4
    --> Techie - Maharaj <-- techiemaharaj's Avatar
    Mar 2012
    Delhi N.C.R
    ^^Ya that happens when battery is low...
    but it might have been completely discharged in this case..
    Get a new CMOS battery and replace it, you could find it at a local watch repair shop also/..things should be fine then..
    Founder: Atumaharaj.com
    Current Rig: Intel i5-760 3.0 GHz | Gigabyte H55M-S2 | Transcend 4GB DDR3 1333MHz | Sapphire HD 6670 1 GB DDR5 | WD 500 GB | CoolerMaster Elite 431 - Transparent Side Window
    Old Experiment Rig: Intel P4 1.6 Ghz | Intel 945 | Hynix 1.2 GB 1333 MHz | Nvidia 6200 256 MB | Samsung 40 GB
    Other Stuff: Samsung Galaxy 5670 | Seagate 500 GB USB 2.0 | HP Mini
  1. Error message when booting windows
    By Anish in forum Software Q&A
    Last Post: 05-01-2012, 11:46 AM
  2. Replies: 7
    Last Post: 27-06-2010, 05:30 PM
  3. message on booting
    By bkmishra1000 in forum Software Q&A
    Last Post: 08-09-2006, 11:42 PM
  4. Windows XP Booting and Installation Error (LILO Error)
    By arijitraja in forum Software Q&A
    Last Post: 26-02-2006, 03:32 PM
  5. error message on booting
    By Thomas K Prakash in forum Software Q&A
    Last Post: 26-09-2004, 10:03 PM
