Results 1 to 20 of 20
  1. #1
    Liverpool fanatic. Vishnupg45's Avatar
    Nov 2011
    Coimbatore,Tamil Nadu.
    Default help me identify the bsod error
    I recently assembled my system. I installed everything from driver cd..
    The problem is i get blue screen every 2nd or 3rd startup.
    Then i can boot my pc and continue work as normal.
    I have taken a pic through my phone. But i dont know how to upload in this post. Pls help.
  2. #2
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Default Re: help me identify the bsod error
    Refit the RAM. check for HDD bad sectors.
    also put the photo in imgur.com which is a image sharing site and then post link here
  3. #3
    Nov 2011
    @techfreak thanks for the link.
  4. #4
    knocking on heavens door sumonpathak's Avatar
    Jul 2011
    Skeleton city
    2500K|3570K|FX-8150|FX-8350|965BE|E7500
    MVF|P8Z77-V Deluxe|P8Z68 Deluxe|CHV|880GM-USB3|M4A785T-M|G31M-ES2L
    HD7850|GTX660Ti|HD6870|HD6670|HD5450|9400GT
    HyperX Blu|HyperX Predator|RipjawsX|Value Select|CGM2X2|
  5. #5
    Nov 2011
    @sumonpathak
    will try and tell at evening.
  6. #6
    Nov 2011
    the procedure is not working
    can somebody tell the exact steps to follow, because i easily miss some or do it in the wrong order.
  7. #7
    Super Geek kisame's Avatar
    Dec 2011
    Gwalior
    Quote Originally Posted by Vishnupg45 View Post
    What driver is shown here.
    Is it virtuWDDM.sys?
    If yes,you have LucidLogix software installed which is causing problems.Uninstall it.
    If its not virtuWDDM.sys,please tell us what is it?It will be helpful in troubleshooting.
  8. #8
    Nov 2011
    yes lucid virtu is there. Do you want me to uninstall it!?
    i5 3450 |asus p8h77-m le |
    G.Skill RipjawsX 2x2GB |Corsair cx500Wv2
    |CM 310 Elite |Gigabyte hd7750 oc|lenovo 611 mouse|20" SamsungSync Master s20b300b
  9. #9
    Jul 2011
    Skeleton city
    uninstall virtu and see if it occurs again...
  10. #10
    Dec 2011
    Gwalior
    Yes uninstall it and check if the problem goes away.
    If it goes away,you will have to google on how to get them working without BSODs.
    If not,then post here.
  11. #11
    Nov 2011
    now the same bsod error but with atikmdag.sys file is displayed. this time it is not virtuwddm.sys, currently virtu is not installed
  12. #12
    Dec 2011
    Gwalior
    This implies now your ATI graphics driver is giving problems.Update your graphics drivers.
    Also post your full PC config for future troubleshooting.
  13. #13
    Nov 2011
    the config is in my signature
  14. #14
    Dec 2011
    Gwalior
    post a screenshot of new BSOD.
    Also try one thing.
    Uninstall CCC but not the drivers and see if the problem goes away.
    If it does not,then some third party software is causing ati driver to crash.
    Give a list of installed softwares.
    Not every software.Softwares you think that can interfere should be listed.
  15. #15
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    Which version of Catalyst are you using?
    Also do tell us the model number of graphics card you are using.
  16. #16
    Nov 2011
    i m trying to get the screen shot, in the mean time here is the error information of the bsod.
    Problem signature:
    Problem Event Name: BlueScreen
    OS Version: 6.1.7600.2.0.0.256.1
    Locale ID: 1033
    Additional information about the problem:
    BCCode: 116
    BCP1: FFFFFA80082FB010
    BCP2: FFFFF880044079E0
    BCP3: 0000000000000000
    BCP4: 0000000000000002
    OS Version: 6_1_7600
    Service Pack: 0_0
    Product: 256_1
    Files that help describe the problem:
    C:\Windows\Minidump\061512-31137-01.dmp
    C:\Users\PG\AppData\Local\Temp\WER-49967-0.sysdata.xml
    catalyst info
    catalyst version 12.3
    driver packaging version 8.95-120131a-132694E-ATI
    catalyst control center version 2012.0131.2220.39925
    here is the image
    http://imgur.com/f9k9X.jpg
  17. #17
    Nov 2011
    ok now i updated the catalyst control center to 12.6 beta and i m yet to get the bsod. Will tell if i succeeded.
  18. #18
    Apr 2012
    london
    bro one more thing replace your ram with new one or with your friends and see problem still remains because if ram get weaker than it didnt load files properly.
    Regards
    Frank
    http://www.testchief.com/
  19. #19
    Aug 2011
    Kolkata
    Then it was just a driver problem.
    My tip: Don't update your driver if it is working perfectly at any point of time.
  20. #20
    Nov 2011
    ya its working for now. I have no virtu installed now. Any suggestions on virtu!?
  1. BSOD CLOCK_WATCHDOG_TIMEOUT error
    By zenoxas in forum Software Q&A
    Last Post: 27-11-2011, 03:18 AM
  2. BSOD error.
    By zegulas in forum QnA (read only)
    Last Post: 29-08-2008, 10:05 AM
  3. BSOD Error Help
    By kantiman in forum Hardware Q&A
    Last Post: 08-04-2008, 04:42 PM
  4. i m getting bsod error
    By sahaymr in forum Software Q&A
    Last Post: 29-11-2006, 12:34 PM
  5. I get this error in BSOD
    By thetopcyborg in forum Software Q&A
    Last Post: 03-09-2006, 09:06 PM
