Results 1 to 28 of 28
Thread: Cpu usage
  1. #1
    Alpha Geek avichandana20000's Avatar
    Jan 2010
    India, City of Joy
    Default Cpu usage
    My CPU USAGE fluctuates heavily even when i am doing nothing and computer remains idle.
    In the Catalyst Centre under Power i have made it MINIMUM 800Mhz and Max 3200Mhz.
    i have done a screen record also:
    http://img706.imageshack.us/img706/2654/jn6.mp4
    pl suggest.
    Sorry guys wrong post in this section.
    Mods are requested to move it to Software section.
    NZXT PHANTOM WHITE+3INTAKE 2EXHST|GA990XA UD3|955BE 3.6(O.C.ed)|MX-2|HYPER EVO|SAPPHIRE 6670 1GB DDR5|DELL SP2309W|CORSAIR XMS 2X2GB 1333|450VX|SEAGATE 1+1 TB|LOGITECH G110|APC 650 VA|+WD MY PASSPORT 3.0 1 TB
  2. #2
    Alpha Geek koolent's Avatar
    Oct 2010
    Rawatbhata, Kota, Rajasthan
    Default Re: Cpu usage
    Just to reply:
    Let me sleep and research a bit . Will reply with an answer soon..
    Intel Core 2 Duo @ 2.8 GHz, Corsair CX430 v2, 3 GB DDR 2 RAM, MSI R6770 MD1GD5 (finally), MSI MS-7525 (v1.0), Compaq W185q 1366 X 768 HD LED Monitor
  3. #3
    Undead!!! Sujeet's Avatar
    Dec 2011
    India
    Quote Originally Posted by koolent View Post
    Just to reply:
    mR. khool cool Koolent i dont think its a property deal or something, or any kind of race so that you have to reserve your space for your UPCOMING post/reply.Try to make replies only after completing your research work in your dreams.
    Stop that absurd act.
    @OP.
    Install a decent AV like Avast and run a complete scan.
    Maybe a Virus.
    Or Try MALWAREBYTES for quicker cleanups.
    HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
    HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
    Samsung Galaxy Tab 2 |7.0 P31000
  4. #4
    Oct 2010
    Quote Originally Posted by Sujeet View Post
    @OP.
    Maybe a Virus.
    LOL, Sorry.. but ok, Sorry again.. LOL
    @OP- Which antivirus you got ?? and though using malwarebytes is also real useful when you don't want to download a huge file
    There can be a virus or you have more than required amount of applications running in the background, check that up..
  5. #5
    Jan 2010
    India, City of Joy
    @Sujeet: i already have KIS loaded, sigle user single PC version. Full scan not done recently.do i still need to run malwarebytes? if yes where can i get one?
    @ Koolent: If more than required applications are running in background where to check and how to stop that? I am also
  6. #6
    Human Spambot thetechfreak's Avatar
    Nov 2008
    Guwahati
    Seems like a virus. Download any free AV like Avira or AVG and do a scan from safe mode. also try this- HouseCall - Free Online Virus Scan - Trend Micro USA
    edit: Also try Malwarebytes Antimalware.
  7. #7
    Dec 2011
    India
    Quote Originally Posted by avichandana20000 View Post
    Install Ccleaner and run a complete cleanup.After that remove all unwanted Startup Program entries using Cleaner Utility.
    CCleaner - PC Optimization and Cleaning - Free Download
    Download Malwarebytes.
  8. #8
    Jan 2010
    India, City of Joy
    this i am not understanding. When i already have a licensed version of KASPERSKY Internet Security 2012 why do i require a free AV.
    Again i download HOUSECALL will not get caught by KIS as virus?
  9. #9
    --> Techie - Maharaj <-- techiemaharaj's Avatar
    Mar 2012
    Delhi N.C.R
    This might help...
    As far as what I had studied in my Engineering Subject and some extra reading on Operating Systems, it seems that a processor is designed to NOT sit idle,it always has to do some work...hence you always see it range from 20 - 40 %..and its said that for a standard computer that much is normal...processors that are on full load may show 95-97% usage..
    Founder: Atumaharaj.com
    Current Rig: Intel i5-760 3.0 GHz | Gigabyte H55M-S2 | Transcend 4GB DDR3 1333MHz | Sapphire HD 6670 1 GB DDR5 | WD 500 GB | CoolerMaster Elite 431 - Transparent Side Window
    Old Experiment Rig: Intel P4 1.6 Ghz | Intel 945 | Hynix 1.2 GB 1333 MHz | Nvidia 6200 256 MB | Samsung 40 GB
    Other Stuff: Samsung Galaxy 5670 | Seagate 500 GB USB 2.0 | HP Mini
  10. #10
    Dec 2011
    India
    Download Process Hacker 2.27
    Run it and sort the Process by CPU Usage.
    You will come to know whcih process/program is using maximum CPU Threads.
    This can be done using Task Manager too but IMO Process Hacker makes the task easier with neat Interface and Tree structured Process Management.
    Well it seems its KIS only that is hogging the system during Idle mode.
    It must be performing cleanups or scans and thats why The CPU usage shoots Up.
    Use Process Hacker as mentioned Previously to confirm It.
    Quote Originally Posted by techiemaharaj View Post
    This might help...
    I am unable to get whatever you are trying to say.
    But anyways take a look at Process Chart(Task Manager) for System while Idl-ing.
  11. #11
    Jan 2010
    India, City of Joy
    which one of Process hacker to be download : Portable, setup,Source or SDK?
  12. #12
    Mar 2012
    Delhi N.C.R
    What I want to say is that, a processor is designed to make use of all the resources available and to do some work all the time. In the attached image we arent using the computer , but still the CPU usage is 1%.
    The Goal is not to let the CPU sit idle...you'll never see a 0% CPU usage..and due to all the background stuff running (like DHCP / DNS stuff, Gadgets, Networks etc.)...the CPU usage is never 0%
  13. #13
    Dec 2011
    India
    Setup will be fine for you.
    Ofcourse even a single line of code under execution is bound to use atleast one CPU thread so definitely with so so much background prcesses running CPU usage will never idle at 0%.
    But according to OPs problem there is heavy CPU usage fluctuation(check video) and that not common thing.
    At idling CPU under normal scenario should constantly float within a threshold range that depends on System Configuration and OS installed
  14. #14
    Oct 2010
    Wink Re: Cpu usage
    ^^ Sujeet is right, the CPU usage is really hard to ignore and that the OP has a Kaspersky, how might it be a virus.. :/.. This is going Crazzy..
    Researching more..
    EDIT- @OP Bro, post your CPU temps here.. Let us check once..
  15. #15
    Jan 2010
    India, City of Joy
    cpu core temp from 43 to 49 while ambience is 37 degree now in kolkata.
  16. #16
    Aug 2007
    Chinchwad Pune
    Check with root kit scanners and also another AV. Its not like Kapersky detects all root kits and viruses.
    Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
  17. #17
    Oct 2010
    ^^ Thumbs up.. +1.. Do that, it might find something..
  18. #18
    Jan 2010
    India, City of Joy
    Give me a link for rootkit scanning.
  19. #19
    Dec 2011
    India
    I think You should do some searching for yourself.
    Will be useful in Long Term
    We cant spoon feed anyone for every thing.
    You gotta do it for yourself at the end of the day.
    Google is your best Friend.
  20. #20
    Jan 2010
    India, City of Joy
    Thanks for the advice.
    I return home from office at 12 a.m.and need to take care of my daughter. So i do not get much time to find anything over my 2g speed Internet.That's why just asking for a help from someone who already knows it.
  21. #21
    BMG ftw!! d6bmg's Avatar
    Aug 2011
    Kolkata
    I think I can't post all kind of link here in this forum. Same rule goes for everyone. I think you have understood my point of view.
  22. #22
    Jan 2010
    India, City of Joy
    yes bro.
    Now here is the Process Hacker screenshot
  23. #23
    Nov 2011
    NCR
    according to the video you posted ~29% was the avg cpu usage of the recording process itself.you also seems to be using fancy desktop themes/gadgets which again will eat cpu resources not to mention kaspersky also monitoring such process activities.just try default windows theme with no gadget/sidebar & if still there is high cpu usage during idle time then reply.
    process explorer screenshot seems ok with usual cpu usage & processes.
    Is God willing to prevent evil, but not able? Then he is not omnipotent.
    Is he able, but not willing? Then he is malevolent.
    Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
  24. #24
    Jan 2010
    India, City of Joy
    Currently i have only 3 gadgets - System monitor II, Network Meter and Weather.
    Changed to Windows classic theme. Now it seems to be within range. but looks like i am using win95.
    Everyone wants to make his windows theme a stylish one specially in win7. For that, should cpu usage oscillates wildly.
  25. #25
    Oct 2010
    Hehe.. But look at the poor fellow yar, what if you had to browse at 2G speeds ..
    @OP-I think you should get a new 3G or Broadband.. The 2G life sucks .. But I don't think you can post such links here to.. Get th point..
  26. #26
    Jan 2010
    India, City of Joy
    got the point. I have KS TDSKILLER. have run it without any threats detected. Currently running Malwarebytes.
  27. #27
    Jan 2012
    You probably have virus in your computer. I had the same issue before when I was not doing anything at all. Then I used virus scan and computer was full of virus. But my norton was not able to remove it so I reinstall the computer and it is working really well again.
  28. #28
    Nov 2011
    NCR
    i am using windows 7 aero theme(not basic) with no gadget on an intel atom system with kaspersky 2012 & idle cpu usage is between 1-8%.your screenshot looks like you are using some 3rd party theme kinda like tiles in windows 8.just use aero theme & windows inbuilt/official gadgets(e.g.system monitor is not microsoft's gadget) then see the usage.
  1. Too much HDD Usage?
    By mitraark in forum Hardware Q&A
    Last Post: 16-04-2011, 10:14 PM
  2. 100% CPU Usage
    By midhunmon in forum Hardware Q&A
    Last Post: 07-05-2008, 12:38 PM
  3. Cpu usage ?
    By shreyadr in forum CPU / Motherboards
    Last Post: 17-03-2007, 12:08 PM
  4. cpu usage 100 %%
    By rcd in forum CPU / Motherboards
    Last Post: 11-11-2004, 03:43 PM
  5. CD-RW Usage
    By khandu in forum QnA (read only)
    Last Post: 23-08-2004, 06:10 PM
