Results 1 to 3 of 3
  1. #1
    not a newbie..... papul1993's Avatar
    Apr 2009
    Assam
    Default Compufer fails to boot. Possible RAM problems
    Hi,
    I have been facing a booting problem recently. The computer takes 2-3 reboots and only after that it becomes stable. I first got a CMOS checksum fail error. Also the date and time got reseted after every boot. So I replaced the small battery in the mobo. But I kept getting boot problems.
    On the first 2 boots the computer hangs up in the BIOS or OS within the first 5 mins. In the next boot I get the error, "DQS training failed. System reverted to slower DRAM speed. Press DEL to continue.". After this the system boots up fine.
    When I bought the computer I had to settle with low quality RAM. I guess it has reached its end of life.
    My full computer config is:
    AMD Phenom 2 550
    Biostar TA785G mobo
    2x2 GB DDR3 (made by Hyundai Electronics as shown by AMD Overdrive.)
    500+1000 GB Seagate HDD
    Coolermaster 600w SMPS ( willing to change this. Suggeations welcome)
    If I have to change the RAM please suggest a good 4GB kit. Budget is 2.5k.
    Budget for PSU is 3k.
    EDIT:So I took out the RAM and cleaned the contacts and then interchanged their positions. Computer working fine ever since.
  2. #2
    amr
    amr is offline
    May 2012
    Default Re: Compufer fails to boot. Possible RAM problems
    have you tried memtest86???
    for DQS training...either disable it or simply load failsafe defaults in the BIOS.
  3. #3
    Oct 2011
    Bangalore
    I think this is definitely ram, swap your ram with friends and see if its solve your problem.
  1. Windows 7 fails to boot...plz help!!
    By twinik in forum Hardware Q&A
    Last Post: 22-03-2012, 10:41 AM
  2. Hard Drive Fails to Boot.
    By Pra1971 in forum Hardware Q&A
    Last Post: 14-03-2010, 12:52 PM
  3. Replies: 12
    Last Post: 26-02-2007, 01:25 AM
  4. Anyone Help Plz - Motherboard Fails To Boot
    By niggers in forum Hardware Q&A
    Last Post: 14-05-2006, 10:08 PM
  5. boot problems
    By ashfame in forum Software Q&A
    Last Post: 07-05-2006, 04:25 PM
