Results 1 to 11 of 11
  1. #1
    Ðèåd Måñ Wå£KîÑG bad_till_bones's Avatar
    Jan 2007
    Default Connecting Laptop to Television
    Hi guys,
    I want to connect my Laptop to an old BPL television. Both in terms of Audio & Video.
    Want to use HDMI/VGA/7-pin SVideo port of the Laptop.
    TV being old only has a RCA slot. TV's RCA slot pic is below -
    Did some search and seems I would be needing the below two cables! But need some confirmation on the same.
    For Video -
    For Audio -
    Guys, please help on this!
    Please someone answer to this! Thanks.
    Once the game is over, the King and Pawn goes to the same box....
  2. #2
    Undead!!! Sujeet's Avatar
    Dec 2011
    India
    Default Re: Connecting Laptop to Television
    Well AFAIK the laptop dont comes with RCA connectors so how will you do that?
    HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
    HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
    Samsung Galaxy Tab 2 |7.0 P31000
  3. #3
    Jan 2007
    Quote Originally Posted by Sujeet View Post
    Brother, using S-Video slot of the laptop for video.
    And 3.5mm headphone slot for audio.
    BTW - Guys bought the above cables Nvidia detects the TV, but no display!
  4. #4
    Nov 2011
    NCR
    you have to correctly configure the nvidia driver settings to use s-video on secondary display & also use use the option "projector/secondary monitor only" while switching displays using windows 7 inbuilt display settings.it would be more helpful knowing the resolution & refresh rate(usually v-sync) of tv but i doubt you still have the manual.
    Is God willing to prevent evil, but not able? Then he is not omnipotent.
    Is he able, but not willing? Then he is malevolent.
    Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
  5. #5
    Jan 2007
    Quote Originally Posted by whitestar_999 View Post
    Bro,
    Can u please check your PM!
    Or please explain what are the correct settings that I have to configure for Nvidia? Basically I am using Dell XPS M1530. Nvidia 8600M display card. OS - Win 7 64 bit Home Premium.
    And I hope I have bought the rite cables?
  6. #6
    Dec 2011
    India
    In Nvidia Control Panel.
    Browse To Display Settings.
    There all The Video Output Will be listed.Like HDMI/DVI/VGA/S-Video etc.
    You can configure any of the output once they are active(port should be in use).
    Just Input the correct Settings Like Set Output Resolution to the supported or Native Resolution of TV and same for refresh Rate.
  7. #7
    Jan 2007
    Bro, I am using 285.62 version of driver. And I am unable to locate the settings that you have mentioned!
    What to do? Please guide me!
  8. #8
    Nov 2011
    NCR
    see here:
    How to Use S Video on NVIDIA Graphics Cards | eHow.com
    it seems like you have to select input in tv also.also first use window logo key+P shortcut to activate multiple display options in windows 7 as i mentioned in my pm & then try nvidia control panel as mentioned in above link.
  9. #9
    Jan 2007
    see here:
    Bro, thanks for the link. But its for Svideo at both the ends. But in my case, TV has a RCA slot.
  10. #10
    Nov 2011
    NCR
    found a link for you & in my opinion it is not worth the effort you are putting.s-video to rca is a tricky matter & it seems a lot depends on cable as well.
    Connect laptop (VGA/S-video) to TV (RCA)
  11. #11
    Jan 2007
    Bro, u saw the last post of that thread. That guy's video came! But not in my case! N the cable is same....
  1. connecting laptop to my CPU
    By chicha in forum Laptops and Netbooks
    Last Post: 22-04-2008, 10:55 PM
  2. connecting pc wid laptop?
    By varunprabhakar in forum Hardware Q&A
    Last Post: 16-12-2006, 04:30 PM
  3. Problem connecting to television...
    By mario_pant in forum Hardware Q&A
    Last Post: 16-12-2005, 03:53 PM
  4. Connecting laptop thru usb....
    By justo in forum Peripherals
    Last Post: 17-12-2004, 03:15 AM
  5. connecting laptop n PC
    By fire in forum Laptops and Netbooks
    Last Post: 09-12-2004, 02:30 PM
