Results 1 to 8 of 8
03-05-2012, 07:39 PM #1
PC not booting, stuck at motherboard's title screen | MSI 880GM-E35
When I try to turn my PC on, it shows the motehrboard's title screen(or whatever its called!) and nothing else happens. The screen is similar to this: http://images.hardwarecanucks.com/image/lemonlime/motherboards/msi_gd70/msi_gd70_bios1_sm.jpg except that name is different.
When I went to BIOS, HDD, SSD and DVD Drive were not detected.
Its a motherboard problem?
How it started:
In morning I was doing random stuff on ubuntu and it froze suddenly. It wasn't responding so I turned the power off directly and restarted the pc. Instead of asking about which OS to boot into, it just went into windows. I ignored this and kept on using windows. I restarted it some time ago and its showing this title screen only, not moving ahead. I have tried removing each sata cable from motherboard, and it shows "Insert proper boot media" when only one sata cable is inserted.
The beauty of Indian roads is that one needs to look on both sides while crossing a one way road!
▒▒ ¯TF2 COMIC MAKER!_ ▒▒
Drive sensibly, please!
Educated Illiterates
03-05-2012, 07:49 PM #2
Re: PC not booting, stuck at motherboard's title screen | MSI 880GM-E35
check if all SB devices are connected to mobo properly and have power.....
doesnt seem like mobo going bad....
u cud also disable this screen to see whats getting detected whats not see if there is any error showing??!Sweet mother of all that is good & pure! ;)
03-05-2012, 08:14 PM #3
03-05-2012, 08:51 PM #4
SSD Has crashed or corrupted because of your random stuff.
BTW Do you mean to say that your OS is installed on HDD instead of SSD.!HCL ME | Intel i3 310M | 320 GB | 2 GB DDR3 1333 MHz |
HP ENVYM6 | Intel i5 3210M 2.5 GHz | 8GB DDR3 1600 Mhz | AMD Radeon 7670M | 1TB
Samsung Galaxy Tab 2 |7.0 P31000
03-05-2012, 09:11 PM #5
03-05-2012, 11:19 PM #6
SB is South Bridge..
04-05-2012, 01:46 AM #7
04-05-2012, 02:50 PM #8
Gigabyte GA-880GM-UD2H vs msi 880gm e35
By Nipun in forum CPU / MotherboardsReplies: 3Last Post: 22-06-2011, 07:49 PM -
galaxy 3 stuck on boot screen; need help on flashing
By reddead in forum Mobiles and TabletsReplies: 11Last Post: 17-04-2011, 12:33 PM -
screen res stuck at 1440*900 :(
By chicha in forum QnA (read only)Replies: 5Last Post: 18-11-2008, 09:05 PM -
ipod nano 3rd gen: stuck with a white screen
By ronweasley in forum Hardware Q&AReplies: 4Last Post: 07-01-2008, 11:44 AM -
System stuck in shutdown screen!!!
By prankie in forum Software Q&AReplies: 12Last Post: 16-03-2006, 06:04 AM
LinkBack URL
About LinkBacks
