Results 1 to 20 of 20
Thread: Bare minimum UPS for this rig.
31-03-2012, 05:32 PM #1
My friend has placed order for the following components to build a rig.
Intel Core i3-2100
ASUS P8H61-M PLUS V2
GIGABYTE GTX 560Ti OC
Corsair DDR3 4 GB
Seagate Barracude 1TB
SeaSonic S12II 620
HP Optical Drive
Dell IN2030
Which is the bare minimum UPS needed to give a backup of 5-10 minutes? Its just to save data and shut down. Suggest the cheapest one as he's on a tight budget.AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
31-03-2012, 05:37 PM #2
Re: Bare minimum UPS for this rig.
You need bare min. of 800VA ups.
My Gizmos O_O
||Core i7 2600K | MSI Z68A GD80 | MSI GTX560Ti ||
||F&D A555U | Roccat Kave | Funbook | LG Optimus L9 (W) ||
31-03-2012, 06:29 PM #3
800Va and that also from apc or something like that. not local ones like iball.
31-03-2012, 10:18 PM #4
^^How about Intex, Numeric, Microtek etc. APC is too costly for him.
31-03-2012, 10:33 PM #5Human Spambot
- Join Date
- Nov 2011
- Location
- NCR
- Posts
- 2,622
intex 1kva costs ~1800 & should be able to give ~5 min of backup.
Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
31-03-2012, 10:38 PM #6
^^Where its available @1.8K ??Any link??
My Gizmos O_O
31-03-2012, 10:42 PM #7
^1 KVa will at least give 10-20 mins back up, until and unless he's running a benchmark or some really stressful application.
@OP- If you don't face any kind of fluctuation, go for intex otherwise APC, but it will cost almost double.FAQ + answers for new members (Read before asking / messaging any moderator for any query)
Drop Box: Get 500MB free
31-03-2012, 10:44 PM #8Human Spambot
- Join Date
- Nov 2011
- Location
- NCR
- Posts
- 2,622
not online but in markets like nehru place.i am assuming this because intex 600va still costs ~1200 in nehru place(the same as last time i checked 1kva prices).even with some price increase it still should not be more than ~2000.
31-03-2012, 11:06 PM #9
31-03-2012, 11:17 PM #10Human Spambot
- Join Date
- Nov 2011
- Location
- NCR
- Posts
- 2,622
my assumption is based on extreme online power calculator which gave me ~400W with 560Ti.with a power factor of 0.6 a 1kva ups will give 600W & total battery capacity should last for at least ~2-3 min at this max power draw.since 400W is 2/3rd of the max power draw therefore i assumed ~5 min backup.
31-03-2012, 11:18 PM #11
^^ Same problem occurred with my microtek 800Va ups. On idle it would give me around 10-15 min. backup. But, when I play games like Battlefield Bad Company 2, pc would simply restart . After all that issue I bought APC 1.1KVA.
My Gizmos O_O
31-03-2012, 11:46 PM #12
1st of all Intex 1 KVA is not available at 1.8K, it is 2.5K +. 2ndly it can provide backup for almost 30 mins without gaming and more around 15 mins while gaming or running resource hungry apps. But problem with these local companies are that their battery dies too early.
Better get APC 600VA around 2K. It will provide enough time to shut down PC even while gaming. If you can find Numeric then get their 800VA+ or 1 KVA model which are cheaper than APC models.AMD FX 8350 @ 4.5 GHz|16 GB RipjawX 1873 MHz CL10 @ 1.6V|1+2TB Seagate + 1 TB WD Green 64MB Cache|Sabertooth 990FX|Sapphire HD 7950 VApor-X OC with Boost|GT 240 1 GB GDDR5 PhysX|CM690II Advanced|LG D2342P Cinema 3D Display|TX850 V2|2 CM 1600RPM FAN|MX518|Razer Goliathus|Razer Arctosa|Razer Megalodon 7.1 Headset|CM Hyper 212 Plus|APC1.1KVA| Moto Defy Plus with CM 10.1 JB 4.1|HCL Me Y2 Tab (rooted)] XOLO Q800 with Ultimate V2 JB 4.2.1| Galaxy Tab 2 P3100
31-03-2012, 11:47 PM #13
^My APC 600 never gave more than 10 mins back up even without a GPU.
01-04-2012, 01:30 AM #14Human Spambot
- Join Date
- Nov 2011
- Location
- NCR
- Posts
- 2,622
it all depends on load.even APC at full load gives about ~5min of backup.you can calculate the backup time by using this method:
1.calculate total energy output by multiplying max load(given in specifications different from va rating) & backup time at this max load(~5min for APC lesser for cheaper brands).
2.calculate the load of your system when playing games etc(use online power calculator/reviews etc).
3.divide the total energy output you got in step 1 by load obtained in step 3 to get approx backup time in min.
some points to note:
a)cheaper brands use lesser quality batteries whose capacities decreases over a period of time more rapidly than say a brand like APC.though it will decrease over time.
b)APC clearly states(& numeric too i think) the max power rating(different from VA & is in watts).for cheaper brands like intex multiply VA rating with 0.6(assumed power factor may be higher but just to be on safe side,APC has a power factor of ~0.67) to get max load in watts.Is God willing to prevent evil, but not able? Then he is not omnipotent.
01-04-2012, 07:26 AM #15
01-04-2012, 08:21 AM #16Broken In
- Join Date
- Jul 2008
- Location
- Nasik
- Posts
- 115
APC 1.1 KVA cheaper thn APC 1KVA . Take APC 1.1KVA best for u. I used Intex 1KVA n belive me its totally crap . Burnt out within a year . Bcoz of burn warrnty also void. So stay away frm Intex , Iball etc local brand .
01-04-2012, 09:11 AM #17Human Spambot
- Join Date
- Nov 2011
- Location
- NCR
- Posts
- 2,622
APC 1kva is coslier than 1.1kva because it has extra feature of monitoring software through usb port etc.
01-04-2012, 09:29 AM #18
^^Anyways he won't be needing the monitoring stuff. So it'll be either Numeric 1KVA or APC 1.1KVA. There is no other cheaper option right?
15-04-2012, 04:17 PM #19
He settled down for Intex 1KVA and changed the PSU to Seasonic S12II 520.
I've got a doubt now. The UPS specs say that its 1000VA/500W. So if he OC's the card & add more optical drive/HDD's and the wattage crosses 500, will the UPS be able to provide backup or will it turn off all of a sudden?
And also how much watts can Seasonic S12II 520 provide? Is it exactly 520 or a bit more?AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
15-04-2012, 05:49 PM #20
By RiGOD in forum PC Components / ConfigurationsReplies: 19Last Post: 15-04-2012, 05:49 PM -
bare minimum rig and min $$
By echo9 in forum PC Components / ConfigurationsReplies: 40Last Post: 14-03-2012, 04:13 PM -
Suggest PSU for bare minimum system
By casual_gamer in forum PC Components / ConfigurationsReplies: 2Last Post: 03-08-2011, 07:28 PM -
Bare requirements
By RandomNumber in forum Hardware Q&AReplies: 7Last Post: 08-09-2008, 08:35 PM -
2G iPod Shuffle stripped and left bare for the world to see
By naveen_reloaded in forum Random NewsReplies: 4Last Post: 16-11-2006, 08:00 PM
LinkBack URL
About LinkBacks
