Results 1 to 9 of 9
Thread: Computer Lagging please help
27-03-2012, 09:40 AM #1Right Off the Assembly Line
- Join Date
- Dec 2011
- Posts
- 5
My PC configuration is:-
Processor- Intel Core2 Duo E7500 @ 2.93Ghz
Motherboard- XFX MG-63MI-7109
RAM- 4GB
Hard Disk- 232GB
Graphic Card- Ati Radeon 6850 HD "1GB"
Operating System-Windows 7 32-bit
I defragmented my hard disk, scanned for any viruses "nothing found" did all the tweaks & tricks i could
, then the last thing i did was formatted my PC but to the surprise my computer still lags and all my games lags too, what might be the problem PLEASE PLEASE HELP ME.
27-03-2012, 12:34 PM #2Wise Old Owl
- Join Date
- Aug 2007
- Location
- Chinchwad Pune
- Posts
- 1,461
Re: Computer Lagging please help
Clean the cabinet. Check the Hardware Temps. CPU tends to slow down when temp goes up.
Phenom II 955 BE | Gigabyte GA-880 GM - USB3 | CM Hyper 212 EVO | Zotac GTX 560 Ti | RIPJAWS 2 x 2 GB DDR3 1600 | Cosair HX750W | Kingston v300 SSD 240 GB | Seagate : 1 TB | NZXT Phantom 410 | Sony Experia Neo V
27-03-2012, 02:34 PM #3Apprentice
- Join Date
- Mar 2012
- Location
- Secunderabad
- Posts
- 75
4GB? It must show(and use) something less in Windows 7 32 bit. Install a 64-bit OS.
One: { Intel i5-2500, Intel DH67VR, 2x4GB DDR3 1333MHz, 1TB, LG supermulti External, Flatron w1943SE, ... }
Two: { Pentium D 805, -----, -----, 200 or 120 or both GB :D, -----, ... }
Three :D: { Pentium III 900MHz, Intel D815EEA, 2x256 MB 100 MHz, 40 GB, ... }
27-03-2012, 06:53 PM #4Right Off the Assembly Line
- Join Date
- Dec 2011
- Posts
- 5
[QUOTE=Tech_Wiz;1614121]Clean the cabinet. Check the Hardware Temps. CPU tends to slow down when temp goes up.[/QUOT
I cleaned the cabinet, motherboard and everything and now it is working FINE
NO LAGGING
seriously i never thought a dust can make a computer LAG THANK YOU very very much for your help
31-03-2012, 04:40 AM #5
Clean up the Temp folder and close Unnecessary application from task manager and from processes tab and reduce Unnecessary start up application by UN checking then in MS config menu if possible ..
Hope this help
31-03-2012, 05:49 AM #6
@ OP - check your HDD for bad sectors ... use win7 x64 with SP1 and install all latest updates for the OS and hardware drivers and tell us in details what type of lag you are facing.
Who Dares Wins
Avenging Angel !
Phenom II 955BE↔Asus M5a97 R2.0↔Corsair 2x 4GB RAM↔HD6850↔Corsair GS600↔CM Hyper 212↔CM 430 Elite
My Blog : http://topgeartopspeed.wordpress.com/
BlackListed : Viewsonic, Gigabyte
05-04-2012, 05:40 PM #7
what is the model No. of the Hard drive u r using. It maybe of less RPM if not, Get a new SSD for the windows OS and use your current HDD as storage Drive.
05-04-2012, 07:32 PM #8
i have used 5400rpm HDD. doesn't lag. it is something else for sure.
06-04-2012, 03:51 AM #9
Who Dares Wins
Avenging Angel !
[SOLVED] Battlefield 3 Lagging...
By Krishna in forum GamerzReplies: 29Last Post: 12-04-2012, 07:45 PM -
By chandra1106 in forum PC Components / ConfigurationsReplies: 3Last Post: 27-03-2012, 03:40 PM -
GTA San Andread lagging
By nilanko in forum GamerzReplies: 1Last Post: 04-05-2011, 03:42 PM -
Is Ur Cityville Lagging
By Goten in forum Chit-ChatReplies: 7Last Post: 10-03-2011, 08:22 PM -
ISRO lagging behind
By adi007 in forum Chit-ChatReplies: 6Last Post: 03-01-2011, 12:02 PM
LinkBack URL
About LinkBacks
