Results 1 to 14 of 14
  1. #1
    savage Computing... savagex's Avatar
    Apr 2009
    Bangalore
    Question What are the role of a CPU and GPU in relation to gaming
    Hi Guys,
    Having this question for a long time now. Tried to google but to no avail.
    While browsing through the threads, people have suggested CPUs which are good for gaming. But isn't the GPU responsible for rendering the graphics ?
    What exactly are the role of a CPU and GPU in relation to gaming ?
    It will be very good if somebody can post a technical writeup or any link for this.
    Highly appreciated !!
  2. #2
    SoLa BeLLaToR... RiGOD's Avatar
    Feb 2012
    Migrator
    Default Re: What are the role of a CPU and GPU in relation to gaming
    Strict buying advice here mate.
    AFAIK GPU plays the most crucial part in gaming at higher resolutions (Full HD or greater). As the resolution is lowered the load on the GPU is eased and it might become CPU intensive. And the main thing is that you CPU should not bee too outdated or else it'll bottleneck the performance of your GPU. Correct me if I'm wrong.
    AMD Phenom II X6 1605T | ASUS M5A88-M | G.Skill RipjawsX 1600MHz 4GB | MSI N560GTX-M2D1GD5 | Seagate Barracuda 1TB | SeaSonic S12 II 520 | BitFenix Merc Alpha | Asus DRW-24B3ST | BenQ G2222HDAL | Lenovo M6811 | Razer Goliathus Control Edition | Logitech K100 | Philips SHP1900 | F&D A-510
  3. #3
    Nov 2011
    NCR
    first of all wrong section.should be in hardware Q&A or Graphic Card section.as for your query a simple explanation is here:
    Budget Gaming PC for 40K
    Is God willing to prevent evil, but not able? Then he is not omnipotent.
    Is he able, but not willing? Then he is malevolent.
    Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
  4. #4
    Apr 2009
    Bangalore
    Sorry guys.... Wrong section....
    Mods please move it to the right section.
    I have a Phenom II X2 550 BE. Would it be able to deliver good HD gaming experience coupled with a good graphics card and 970 chipset based mobo ?
    @whitestar_999 : Also can you give me a more detailed explanation ?
  5. #5
    Fast 'N' Furious topgear's Avatar
    Jul 2006
    Geek's Heaven
    ^^ with a good GPU your CPU is capable enough to handle all of the latest games .. if you need extra performance boost try unlocking the cpu into a quad core
    Who Dares Wins
    Avenging Angel !
    Phenom II 955BEAsus M5a97 R2.0Corsair 2x 4GB RAMHD6850Corsair GS600CM Hyper 212CM 430 Elite
    My Blog : http://topgeartopspeed.wordpress.com/
    BlackListed : Viewsonic, Gigabyte
  6. #6
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    I'll explain in a very simple language.
    Theoritically, a CPU has to be fast enough to feed the insturctions to the GPU.
    Small hypothetical examples.
    Example #1
    You pair HD 6570 with a Pentium 4. You get 40 FPS in a game. Then you pair HD 6850 with a Pentium 4. You still get ~40 FPS in a game.
    This was an example of "CPU bottleneck" - in which CPU was not fast enough to run the game and feed instructions to the GPU. So if using a Pentium 4, then getting anything above HD 6570 will give you zero benefit in games.
    Example #2
    Guy X purchased Phenom II X4 965 BE (Rs. 7500), a motherboard (Rs. 6000) and HD 6970 (Rs. 21000). Total cost = Rs. 34,500.
    Guy Y purchased Core i7-930 (Rs. 13000), a motherboard (Rs. 10000) and HD 6850 (Rs. 11000). Total cost = Rs. 34,000.
    Core i7-930 is the faster processor than Phenom II X4 965 BE. But Guy X's computer will be faster than Guy Y's computer in games.
    Reason? Guy X has a much much faster GPU. And Phenom II X4 965 BE might be quite a bit slower than Core i7-930, but it is in no way a "bottleneck" and still powerful enough to feed a HD 6970.
    Example #3
    One more example. X4 965 + HD 6970 vs i7-930 + HD 6970 when playing games at a very low resolution of 1024x768.
    So, in this case we are playing on a very low resolution. Pairing both the CPUs with the same GPU.
    You'll expect i7-930 to win in this case because it is the faster CPU afterall. In low resolutions, you are not "working" up the GPU by much. GPU load will be low and CPU speed will affect the winner.
    Less resolution = CPU bound. But no one games at these resolutions anymore. 1920x1080 performance is what everyone should look at.
    Example #4
    X4 965 + HD 6970 vs i7-930 + HD 6970 when playing games at 1920x1080. You could say this is a high resolution.
    In this case, don't expect the gap between both the configs to be much. Both will perform similarly. May be the i7-930 config will win, but not by much.
    Both processors are avoiding the bottleneck and 1920x1080 resolution is more GPU intensive. GPU load will be high.
    More resolution = GPU bound.
    Example #5 - multi-GPU and multiple displays.
    a)
    Let's use HD 6990 + HD 6970 "Trifire"....that's three GPUs. Resolution = 5760x1080. Three 1920x1080 displays. Processors we will use are FX-8150 vs i5-2500k.
    Resolution is very very high - both CPU and GPU will get worked. In this case you'll see that i5-2500k will win if the game is CPU intensive. Because FX-8150 is the slower processor.
    Multi-monitor resolutoin gaming = the type of game will make a huge difference here. GPU intensive obviously, but if the game is CPU intensive, CPU performance will make a difference.
    b)
    HardOCP had tested GTX 580 2-way SLI and 3-way SLI on i5-2500k and FX-8150 respectively. Their result:
    Quote Originally Posted by HardOCP
    If you are running dual-GPUs, such as 2-way SLI, this again will be dependent on the game, but also the resolution. There are several games that show some major differences between the CPUs, even with 2-way SLI, such as ARMA 2, Crysis Warhead and Civilization V. On the other hand there are games that do not, DiRT 3, Dragon Age 2, Metro 2033.
    What is very clear though, is that with 3-way SLI, performance was continually better, and noticeable to a large degree, with the Intel 2500K CPU. It seemed to us that the AMD FX-8150 CPU was holding back the performance of 3-way SLI.
    AMD FX-8150 Multi-GPU Gameplay Performance Review
    Now we have games. Few games are single-threaded and few are multi-threaded. Majority of games now use 2 threads at the moment. But from 2010 we are seeing that most games are utilising 4 threads.
    Starcraft 2 - for example. Single-threaded and CPU intensive. Core i3-2100 (2 cores/4 threads) will win against Phenom II X4 965 BE (4 cores/4 threads) regardless of the GPU you use. SC2 is very CPU intensive - almost like a low-resolution game scaled up.
    GTA IV - very CPU intensive game. The more cores you add, the better it is. X4 965 BE being a quad-core will win against i3-2100 (dual hyperthreaded cores). Faster GPU made no difference for this game. All it needed was 4 cores and overclocking to run properly when it was released. Nothing less.
    Resident Evil 5 - can make use of upto 8 threads. FX-8150 (8 cores) might have a chance against i5-2500k (4 cores) here.
    Battlefield 3 - an example of dual-threaded GPU intensive game. No matter how many cores and which processor you throw at it (Phenom II, FX or Sandy Bridge) - it used only 2 threads and performed equally. The GPU solely defined the performance in this game.
    Civilization V - multi-threaded, very CPU intensive and very GPU intensive.
    Nutshell: Gaming performance = mixing and matching of many things. There are aberrations to what I wrote above - but it is still a fair gist overall to the best of my knowledge.
    Regarding your Phenom II X2 550 BE. It alongwith Core 2 Duo E74xx/E85xx is fine for gaming at least for the time being. 550 BE overclocks nicely as well. If you feel it is slow, overclock it. It will not be fine from next year or so. Games are starting to utilise 4 threads now. Pretty much the reason why Athlon II X4 gets more recommendation than this in TDF.
    AMD A8-3870K with Radeon HD 6550D | Digilite A55M (Foxconn) | 2 * 4 GB Corsair 1600 Mhz Value RAM | Corsair CX430v2 | NZXT Gamma | Dell S2240L 22" @ 1080p
    Intel i5-2500K | Asus P8Z68 Deluxe | 2 * 4 GB Corsair Vengeance | WD Caviar Blue 500 GB | CM Hyper 212 Evo | AMD Radeon HD 6950 2 GB | NZXT Tempest Evo | Corsair AX850 | AverMedia AverTV Capture HD H727
    Samsung Galaxy S2 | Mac mini (Late 2009) with OS X Mountain Lion, 10.8
    Pandaboard ES | OMAP 4460 SoC | 2 * ARM Cortex A9 cores | PowerVR SGX540 graphics
    Arch Linux amd64 | Ubuntu 12.04 amd64 + omap4 ARM | Windows 7 x64
  7. #7
    Apr 2009
    Bangalore
    Thanks ico for this worderful, exhaustive explanation.
    This clears a lot of air.
    I will wait for the AMD piledriver CPUs to come out before upgrading this CPU. And yea hopefully can unlock the 550 BE to a quad core.
    Does anybody know a 970 chipset based mobo which can unlock this CPU (ACC) ?
  8. #8
    ico is offline
    . ico's Avatar
    Jun 2007
    Bangalore
    ^^ Unlocking isn't guaranteed.
  9. #9
    food-football-g(f)aming?! amruth kiran's Avatar
    Dec 2011
    bangalore
    DAMN ico. you really put a lot of effort in that explanation. kinda cleared a lot i my head too.!! thanks!!
    BAZZINGA!!!
    one geek to rule them all.
  10. #10
    Simply a DIGITian krishnandu.sarkar's Avatar
    Nov 2007
    Kolkata
    Thanks ico
    It made many of my concepts much clear now
    • Read The Forum RULES First.
    • Before PM'ing Or Asking Any Questions To Any Mod Read The FAQ's
    • Before Starting A New Thread Read The STICKY THREADS First
    • Before Participating In Bazaar Section Read The BAZAAR RULES
  11. #11
    Nov 2011
    NCR
    very good & detailed explanation ico.along with VRM this topic too deserves a sticky in my opinion in gaming/graphics section.
  12. #12
    Apr 2009
    Bangalore
    Quote Originally Posted by ico View Post
    Yea right... it isnt guaranteed.
    but are there any 970 chipset based mobos with ACC so that i can try ?
    AMD Phenom II X4 B40 (unlocked 3 cores of AMD Phenom II X2 550 BE) @ 3.4 GHz, Asus M5A97, 4 GB DDR3 Ram, MSI Cyclone R6850 OC edition
  13. #13
    Section Moderator gopi_vbboy's Avatar
    Mar 2007
    Hyderabad
    ya i think ico post needs to be put in some existing/new sticky thread in gfx section..good expl...
  14. #14
    Jul 2006
    Geek's Heaven
    Quote Originally Posted by savagex View Post
    get Gigabyte GA-970A-UD3 but don't fool around with the ACC option - it's not there anymore ( on any 9xx series mobo ) instead search for a new option called CPU Core Unlocker
    Who Dares Wins
    Avenging Angel !
  1. Replies: 4
    Last Post: 27-03-2012, 05:20 AM
  2. What are the role of a CPU and GPU in relation to gaming
    By savagex in forum PC Components / Configurations
    Last Post: 26-03-2012, 06:40 PM
  3. pci express version's relation with performance
    By Shivam24 in forum Graphic cards
    Last Post: 17-11-2011, 12:32 AM
  4. Relation of Roaming and Internet usage....
    By mkmkmk in forum Internet & WWW
    Last Post: 29-04-2007, 02:14 AM
  5. Nero and my DVDs...not a good relation..
    By shyamno in forum Software Q&A
    Last Post: 30-01-2007, 11:26 AM
