Old 05-02-2012, 07:32 PM   #1 (permalink)
Default how much will it cost to buy the following things from lamington road,mumbai ?
cpu: amd athlon II X4 640 and a compatible ddr3 motherboard(used)
ram:2 gb ddr3(used)
gpu:hd 5770 and a psu for that(used)
a cabinet(new)
160 gb hard disk and a dvd writer(used)
can it be under 16000rs
maknom66 is offline   Reply With Quote
Old 21-02-2012, 09:33 PM   #2 (permalink)
Reverse Engineering rocks
Sid_gamer's Avatar
Default Re: how much will it cost to buy the following things from lamington road,mumbai ?
@maknom66
Why are you buying important components like the proccy and the mobo used ?? And going for a new cabby ?
You will get most of the products mentioned by you in brand new condition at the budget mentioned except the HD5770.
May i know what will be the purpose of this rig ?
i7-920|DFI LanParty DK X58-T3eH6
G.Skill-1600MHz,2Gbx3|ZotacGTX260 AMP2
Seagate 1Tb|CM Silent Pro M600
AOC-2236vW-Full HD|LG DVD/RW
Altec Lansing FX3021|MX-518
Delux DLC SH-490|CorsairH70
Sid_gamer is online now   Reply With Quote
Old 21-02-2012, 11:53 PM   #3 (permalink)
<Sparkling Pwnies>
Anorion's Avatar
wait till march at least, prices at atrocious levels atm
IDDQD IDKFA
Anorion is online now   Reply With Quote
Old 22-02-2012, 03:27 PM   #4 (permalink)
Originally Posted by Sid_gamer View Post
@maknom66
gaming
Old 22-02-2012, 03:32 PM   #5 (permalink)
Mr.V's Avatar
Get the proccesor and mother board new.Its the heart of a gaming system!
Yes you may buy the graphics used but dont buy the proccesor and motherboard used.
Rather get this config :-
AMD A6 LLIANO QUAD CORE 3650 around 6k (5k for tri core)
Gigabyte GA A55M SV2 (around 3.5k)
then get the other components used (if not going into high gaming,the A6 has an HD6530D in it.)
AMD FX8120-Gigabyte GA-990XA-UD3 990X
Corsair Vengeance 8GB DDR3 1600 Mhz
Sapphire Radeon HD 6870-WD 500GB
CM EXTREME 600W
Changed my config! :P
Mr.V is offline   Reply With Quote
- by kool
