Old 04-02-2012, 01:14 PM   #1 (permalink)
Gamer
Default Weird problem with my PSP
I have a PSP 2000 Slim & Lite. I am currently running 6.60 ME 1.6 on it. The problem is, the PSP starts as soon as I enter my battery in the slot, I don'e even need to slide the power key. The screen comes on for like 2 seconds and then the PSP shuts off. It comes back on automatically if I shake it a little or hit it lightly. I'm pretty sure the battery isn't loose because the battery seems to be very tightly fit in its place. Here's a video of my problem
Gaming Rig:
AMD Phenom II X6 1075T @ 3Ghz | ASUS M5A97 | Sapphire HD6850 1GB | Corsair CX500V2 | G.Skill RipjawsX 4GB @ 1600Mhz | WD Caviar Blue 500GB | ASUS DRW-24B3ST | Dell IN2030M | Logitech MX518 | Cooler Master Elite 311
ArjunKiller is offline   Reply With Quote
Old 04-02-2012, 02:07 PM   #2 (permalink)
Stuck in Time...
Vyom's Avatar
Default Re: Weird problem with my PSP
You just inserted the battery with one hand, and immediately rotated the PSP to demonstrate the problem. What makes you so sure that the battery is really right tight?
Marty: Hey, Doc, we better back up. We don't have enough road to get up to 88.
Doc Brown: Roads? Where we're going, we don't need, "roads!" :)
──── On the Internet you can be Anything you want. It's Strange that, so many people choose to be Stupid! ────
Vyom is online now   Reply With Quote
Old 04-02-2012, 06:19 PM   #3 (permalink)
Gamer
Sir, I know it's in place because If the battery would have been loose then the PSP wouldn't even turn on.
Gaming Rig:
Old 04-02-2012, 08:38 PM   #4 (permalink)
Stuck in Time...
Vyom's Avatar
Well, if the battery is set tight, then it can't be the display problem, since if the display would have been damaged, it won't cause the restart of the PSP.
In that case this IS a weird problem.
Sorry can't help. You may need to send it for RMA.
Old 04-02-2012, 09:38 PM   #5 (permalink)
Gamer
It was bought in Singapore in 2008. A new set costs 6.5k, Sony said that repairing will cost 3.5k, so no use of RMA. I guess I will try switching it on after a few days.
Gaming Rig:
- by kool
