Old 31-01-2012, 02:19 PM   #1 (permalink)
Default Laptop display problem
Old gateway p4 laptop with 17 inch display. Display now has bright contrast with gibberish on screen.
Can this display be repaired?
Can someone suggest a reliable and reasonable Laptop repair shop in Nehru place.
Saurav2007 is offline   Reply With Quote
Old 31-01-2012, 08:29 PM   #2 (permalink)
BMG ftw!!
d6bmg's Avatar
Default Re: Laptop display problem
This type of problem occurs in older laptops when internal VGA connection become loose. Just go to any repair shop & tell then to reattach that vga cable.
d6bmg is offline   Reply With Quote
- by kool
