Old 27-01-2012, 04:51 PM   #1 (permalink)
Cool Buddy's Avatar
Default Sata to IDE converter not working
I bought a new motherboard a few weeks back which did not have an IDE port, since my DVD Writer was IDE, I bought a SATA to IDE converter for it. The problem is, my DVD drive is not being detected after I plugged it in. I tried changing SATA ports, tried a different SATA cable, but nothing helped.
The tray is working as it comes out and goes in on pressing the eject button.
Is there something else I can try? Or is the converter faulty?
Nokia 5230 :(
Canon IXUS 115 HS :)
Old 27-01-2012, 05:55 PM   #2 (permalink)
Default Re: Sata to IDE converter not working
you are not the only one.many so called sata/ide converter do not support ATAPI which is different from ATA(or hard disk)support.it all depends on type of chip used.only those chips which support ATAPI can support cd/dvd drives.your converter has ATA support but not ATAPI.as far as i know all cheap converters are only ATA capable & not ATAPI.
Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
whitestar_999 is offline   Reply With Quote
Old 27-01-2012, 09:24 PM   #3 (permalink)
Cool Buddy's Avatar
oops..
Means 140 rupees waste?
Would have been better if I had just bought a new writer
Nokia 5230 :(
Old 31-01-2012, 12:23 AM   #4 (permalink)
Undead!!!
Sujeet's Avatar
faced same prob and met with no sloutions so far..its a waste!!
Hollywood Undead
I want to teach you to live the truth, to reveal the light within your own soul-Swami Vivekanand.
Greatest Troll of Millennium.Here
Sujeet is offline   Reply With Quote
- by kool
