Old 22-01-2012, 11:19 AM   #1 (permalink)
Default Gaming prob
My config
Cpu-intel e7500
Mobo gigabyte ga g41 combo
Gpu -ati radeon hd 5670
Psu-circle raw power550 watt
Os-windows 7
While playing Hd games
Sometimes the game suddenly goes of
Sometimes there is black screen sometimes there are various colour stripes please help
Sumer808 is offline   Reply With Quote
Old 22-01-2012, 11:41 AM   #2 (permalink)
The Warchief
Kola2842's Avatar
Default Re: Gaming prob
This could be a power issue. Did you connected extra power cable of your gpu?
Kola2842 is offline   Reply With Quote
Old 22-01-2012, 12:32 PM   #3 (permalink)
The monitor might be defunct. I guess its a CRT monitor? Check the cable with the GPU. reconnect if necessary.
Old 23-01-2012, 04:54 PM   #4 (permalink)
Mr.V's Avatar
hmm....a 5670?. Try another graphics card and check it.And dont forget the PSU. Which games do you play?
Mr.V is offline   Reply With Quote
Old 23-01-2012, 05:34 PM   #5 (permalink)
check for overheating. use HWMonitor for that not Speedfan. else uninstall current drivers & reinstall.
Old 24-01-2012, 05:26 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
it might be a driver issue as well - use driver sweeper to clean off the old display driver .. download and install latest display drivers and also install latest directX runtime package.
ToPsPeEeD = FaSt BuT StEaDy
Old 24-01-2012, 08:13 AM   #7 (permalink)
Don Draper is coming back
vamsi_krishna's Avatar
Its either heat issue or a power related issue. What are your GPU temperatures while playing the game. Do this problem occur randomly or during a particular sequence?
Sent from my SGH-i917 using Board Express
I am MaxPayne. My Wife and Daughter were murdered.
vamsi_krishna is online now   Reply With Quote
Old 24-01-2012, 09:05 AM   #8 (permalink)
Jaskanwar Singh's Avatar
it might be a bad GPU. same happened with me.
do what topgear said, if it doesnt work, reinstall windows and then install latest drivers and all.
Old 26-01-2012, 03:19 PM   #9 (permalink)
Undead!!!
Sujeet's Avatar
Maybe the games are culprit here..i mean specify the game(games)..if its just a handful of specific games then it might be there fault not hardware's !
Hollywood Undead
I want to teach you to live the truth, to reveal the light within your own soul-Swami Vivekanand.
Greatest Troll of Millennium.Here
Sujeet is offline   Reply With Quote
Old 26-01-2012, 05:10 PM   #10 (permalink)
seems like ur gpu is artifacting.....attributed to gpu overheating....
Since the 5670 is relatively newer model and works very well with the 75Watts it gets from the PCIE slot, Chances of a PSU low load current seems slim.
How is the airflow in ur cabby?? Do you have a wire mess inside?
Have you cleaned the inside?
Are you stressing the GPU like full HD with loads of details?
Coming to ur Display..well crts are known to display such corruption due to bent vga pins..
Check and tell us more,
ADios Bro!
aloodum is offline   Reply With Quote
Old 27-01-2012, 03:53 AM   #11 (permalink)
Fast 'N' Furious
topgear's Avatar
mention the game names and have you tried what I've suggested earlier ?
Old 29-01-2012, 01:51 PM   #12 (permalink)
Call of duty mw 1,2,3
my Gpu is with xfx
but they tell that there is no problem with it
and this is the second time i am doing this
i will inform after i get it back
and will report you
Old 30-01-2012, 03:09 AM   #13 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ try some more resource hungry games like BFBC2, Crysis 2, BF3, BioShock 2 and Metro 2033 - see if they are running smooth or not - also clean the old gfx drivers using driver sweeper and install latest gfx driver.
Old 30-01-2012, 11:29 AM   #14 (permalink)
$$Lionking$$'s Avatar
artifacts = bad gpu. check ur ram too... run memtest86+........
Sweet mother of all that is good & pure! ;)
$$Lionking$$ is offline   Reply With Quote
- by kool
