Old 22-01-2012, 10:21 AM   #1 (permalink)
Question DVD RW not recognised in BIOS
Hi everyone, this is my first post on ThinkDigit. I hope I am at the right place.
The problem I am facing is regarding my Sony DVD RW. I own a Compaq machine with the following config at present:
OS: Windows XP Professional SP2
CPU: Intel Pentium 4 524 3.06 GHz
RAM: Total 1280 MB (2 sticks; 1024 MB, 256 MB )
Motherboard: Gigabyte GA-8S661FXM-775
BIOS: Award S/w international, v F7a
HDD: Western Digital Caviar 250 GB
OD: Sony DVD RW AD-7240
Audio: Realtek AC'97
It came with an IDE HD and an IDE CD RW. After some time I installed the SATA DVD RW in one of the two SATA ports. Everything was working fine and I could boot from my DVD RW. Recently my IDE HD went kaput. I replaced it with a SATA HD (WD Caviar). I had to reinstall the OS in the new HD. At that time also I could boot from my DVD RW. But last week when I tried to install Linux by booting from a live DVD, I couldn't. The BIOS is not showing the DVD RW although its working fine in Windows after booting. I have removed my IDE HD and CD RW. Please help me out.
Dev_t is offline   Reply With Quote
Old 22-01-2012, 11:33 AM   #2 (permalink)
@ndroholic
pramudit's Avatar
Default Re: DVD RW not recognised in BIOS
It is possible that it might be given some different name in bios...
Intel Core 2 Quad Q8400 |Asus EAH4350 HD @ 720/480 need to send for RMA| WD blue 500gb | Intel DG41RQ | 2gb DDR2 | HP DVD-RW | Creative 2.1 | SAMATRON 55V |
Samsung Galaxy Y
Garena id- pramudit
My coil Gun
pramudit is online now   Reply With Quote
Old 22-01-2012, 11:45 AM   #3 (permalink)
The Warchief
Kola2842's Avatar
If it is working in windows then it must be in bios. Insert your linux dvd then restart your pc and while boot press F8 for boot drive selection.
Kola2842 is offline   Reply With Quote
Old 22-01-2012, 01:13 PM   #4 (permalink)
it'll definitely show in bios. else how will windows recognize it? clear cmos & load default settings. check if anything comes.
Old 25-01-2012, 02:32 PM   #5 (permalink)
Undead!!!
Sujeet's Avatar
Your SATA DVD Drive is of which brand??? you should look for brand and drive specific name in BIOS boot menu..for e.g a sony drive will appear something like this in boot menu SONY DVD RW AW-G170A.
Hollywood Undead
I want to teach you to live the truth, to reveal the light within your own soul-Swami Vivekanand.
Greatest Troll of Millennium.Here
Sujeet is offline   Reply With Quote
Old 26-01-2012, 04:44 AM   #6 (permalink)
Fast 'N' Furious
topgear's Avatar
@ OP - just set DVD/CD drive as the primary / 1st boot option in bios setting - this will fix your issue for sure and you'll be able to boot from bootable cd/dvds
ToPsPeEeD = FaSt BuT StEaDy
Old 26-01-2012, 02:46 PM   #7 (permalink)
Thanks guys for suggesting the solutions but the problem is persistent.
I have tried all the solutions
1. Reset the BIOS to default optimal settings
2. Clear CMOS by removing the battery
3. Changing the boot preference. My sequence was:
CD ROM
HDD
USB-HDD
4. Interchanging the cables: since my HDD was working fine so I thought the cable on my DVD RW might have gone wrong. So I switched the cables but it still recognized only one device.
5. Interchanging the ports: I interchanged the ports of the two devices. Now the DVD RW was on the port on which earlier the HDD was working. When I rebooted my PC this time it recognised my DVD RW as SONY DVD RW but it din't recognize the HDD. It won't boot from HDD now and shows DISK FAILURE error.
Another thing. When I tried the no. 5 step I also tried booting using UBUNTU LIVE DVD. It booted from the DVD RW but when I chose the Install Ubuntu option it just got stuck on the first screen with progress bar and won't give any error like "no hard disk" found or something like that..
strange problem
Old 27-01-2012, 03:49 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ congrats ! you have just pin pointed the problem - it's the mobos sata port that gone bad - that's why no device plugged in that port is not working.
Buy a external sata DVD drive enclosure and use the DVD drive as a USB dvd drive
Old 30-01-2012, 03:28 PM   #9 (permalink)
I think you are right topgear...can this be fixed without having to invest in a sata dvd drive enclosure..like replacing the port or something like that
Old 31-01-2012, 05:00 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
^^ you better get a sata enclosure - it just costs around 500/700 bucks
- by kool
