Guys, my config is as below:
AMD Athlon 64 X2 6000+ (Windsor) - Socket AM2 (940)
2 GB Transcend DDR2 Regular UDIMM - PC2-6400 (400 MHz) - (1 GB RAM X2)
Seagate 250 GB hard disk
Frontech 500W PSU bought in 2008 along with system
Everything was working fine till I had this below!
Current Mobo suspected to be bricked by BIOS -> M2N-VM DVI when I was trying to update my BIOS. So then started the problems.
So got the Mobo repaired with latest BIOS. Ever since I fixed the Mobo, am facing newer problems after some time!
Initially, system ran well. Suddenly, the system used to hang and nothing happens. Then when checked the graphics card (Nividia 8600GT), it was getting way heated and hence removed the same. System still worked for some time but in a very slow response!
Now comes the main issue...recently, turned on the PC. Everything seemed to be fine. After 5 min, the monitor went grey and blue lines that were horizontal and slant appeared. When I tried to restart, there is NO DISPLAY!
Waited for 3 days and then tested. Started then but again same issue! Now there is NO DISPLAY. Tried interchanging RAM slots but in vain.
Am confused. Would it be the Mobo or the PSU? If its PSU, how to check?
Pls help
