Old 16-01-2012, 03:24 PM   #1 (permalink)
Smile New UPS
The following is my configuration.
AMD PhenomII 955BE @3.2GHz
Gigabyte GA 880GM-USB3
Sapphire HD 6770
4GB Corsair 1333 Mhz
Dell IN2030M 20" LED
Western Digital 500GB Blue
Samsung DVD+RW
FSP Saga II 500Watt
CM Elite 310
I need a suitable UPS for this rig ..Thank you
[AMD PhenomII 955BE @3.2GHz][Gigabyte GA 880GM-USB3][Sapphire HD 6770 ][4GB Corsair 1333 Mhz][Dell IN2030M 20"][Western Digital 500GB Blue][Samsung DVD+RW][FSP Saga II 500Watt][CM Elite 310]
fractalnoize is offline
Old 16-01-2012, 03:55 PM   #2 (permalink)
Fragholic
Default Re: New UPS
AMD PhenomII 965BE @3.4GHz
Gigabyte GA 785GMT-USB3H
MSI 560 Ti hawk
8GB Corsair 1333 Mh
BenQ g2420hd
3 sata green HDD
Samsung DVD+RW
Corsair vx550
I use a APC 1.1KVA UPS gives 20-25 minutes backup . If you need similar backup go for 1.1kva else you can go for 650KVA .
Intelli 3.0 + Qck Heavy + Logitech g510 + AD700 + Xonar Dx + 560 Ti Hawk Edition
PS3 320GB Move
Galaxy S2
sukant is offline
Old 16-01-2012, 03:58 PM   #3 (permalink)
Default Re: New UPS
a 800VA ups is more than enough.brand depends on your budget.my suggestion is get intex 1.1kva for ~2000.apc 1.1kva is much costlier at ~5000(if you can find at this price).
@sukant,you mean 650VA.
Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
whitestar_999 is offline
Old 16-01-2012, 06:51 PM   #4 (permalink)
Default Re: New UPS
OP what is your budget. I would recommend Intex 1Kva for Rs.1800~
thetechfreak is offline
Old 18-01-2012, 11:31 AM   #5 (permalink)
Default Re: New UPS
well my budget is uptill Rs.1300-1500
Old 18-01-2012, 01:10 PM   #6 (permalink)
Default Re: New UPS
1.5k is less. you still may get 800VA ups from intex or iball.
Sam is online now
Old 18-01-2012, 11:56 PM   #7 (permalink)
BMG ftw!!
d6bmg's Avatar
Default Re: New UPS
Then Intex 800VA.
d6bmg is offline
Old 19-01-2012, 04:42 AM   #8 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: New UPS
IF OP runs everything at stock then a Numeric 600VA will do just fine
ToPsPeEeD = FaSt BuT StEaDy
topgear is offline
Old 19-01-2012, 10:20 AM   #9 (permalink)
Default Re: New UPS
well i do run everything at stock and i am in no mood of changing it any time soon ...but i prefer a bit extra always ..since i may someday try to OC or add additional components ... ok so if i save money and increase my budget uptill 2k ...then ??
Old 20-01-2012, 05:12 AM   #10 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: New UPS
you should always go in for better quality than quantity
Intex 1KVA will cost you ~1.8k but still it's better to go for APC 600VA @ 1.85k for better quality
topgear is offline
Old 20-01-2012, 11:19 AM   #11 (permalink)
gamer
Default Re: New UPS
well i am using microtek (600va) for around 4+ years, and it hasn't demanded any repair/service in these years, it came with a warranty of 2 years including battery also. so you can estimate how good is the battery...
the price now a days is around 1.7~1.8k here in nehru place, Delhi...
also it gives backup of 15+ minutes on my mentioned hardware (in signature)..
intel core2duo e7400 2.80GHz, intel DG41TY, Kingston 3 GB DDR2 800MHz, 1TB seagette SATA, samsung 22x DVD-RW, sapphire AMD RADEON HD 6870 1 GB GDDR5, CM xtremepower 600W, logitech z506, samsung BX2031N, HCL keyboard, microtek 600VA UPS, Nokia Xpressmusic 5320
Shivam24 is offline
Old 21-01-2012, 10:40 AM   #12 (permalink)
Default Re: New UPS
hmmm ...i see ...well microtech is a good company ... i cant go any further beyond 2k ... so your final say guys microtech or APC ??
Old 21-01-2012, 06:40 PM   #13 (permalink)
gamer
Default Re: New UPS
they both are good, i have written my microtek experience as i am using that.
and pleas don't go for any other brands like moserbaer ups, hcl ups or other brands as they are more likely to get damaged in the warranty or just after warranty...
these cheap class ups are manufactured in such a way that they get damaged, mainly the battery just after your warranty is over (battery life is designed only upto warranty period), this says my personal experience with hcl and moser baer ups in past...
EDIT: Prices in cost to cost , NEW DELHI are:
APC600VA : 1800inr
MICROTEK 650VAE2: 1571 inr
Shivam24 is offline
Old 22-01-2012, 04:08 AM   #14 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: New UPS
My recommendation is to stick with APC
topgear is offline
Old 29-01-2012, 09:11 PM   #15 (permalink)
Default Re: New UPS
done !! thanks a tonnn guys
Old 29-01-2012, 09:22 PM   #16 (permalink)
gamer
Default Re: New UPS
your welcome, which one??
Shivam24 is offline
Old 30-01-2012, 04:10 AM   #17 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: New UPS
congrats Let us know about the brand, model, place and price.
topgear is offline
Old 23-03-2012, 03:11 PM   #18 (permalink)
Default Re: New UPS
APC 600v ups ..thanks lott guys ..sorry for the delay !! ^_^
Old 24-03-2012, 03:55 AM   #19 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: New UPS
^^ Thanks for informing
topgear is offline
- by kool
