Old 10-01-2012, 10:36 PM   #1 (permalink)
Constructed New Rig..!!
Default No display from system
Hi,
I have two systems, one display Dell ST2220L and Graphic Card XFX 8800GT 512MB.
System 1:
Intel C2D E6550
Gigabyte G41 Combo
Kingston 2x1GB DDR2 800MHz
Corsair VX450
This system was working fine with GFX and monitor mentioned above.
System 2:
AMD Phenom II X4 955BE
Gigabyte 880GM USB3
Corsair 2x2GB DDR3 1600MHz
Seasonic 620W
For both the systems, I am connecting my monitor from GFX card via DVI to VGA connector as from motherboard it would not get signal and monitor go in sleep mode.
I tried to connect system 2 to the display but monitor was not getting display and was going in sleep mode. I re-installed RAM modules and it got started. I am though not sure about display output from motherboard after re-installing RAM modules.
Now coming to system 1,
I tried to connect display directly from motherboard. Result -> no display.
I put Graphic card and connected display via DVI to VGA. Result -> no display.
I put one module of DDR2 RAM at a time in each slot. Result -> no display.
I put one module of DDR3 RAM at a time in each slot. Result -> no display.
I replaced mobo and also checked and confirmed about display in service center.
Again at home same, all 4 above scenario repeated. Result -> no display.
I tried to reset BIOS and repeat steps. Result -> no display.
I put no RAM, Result is obvious no display but no beep code too. (true for both my Gigabyte mobo)
Can not cross check SMPS as Seasonic has 8 pin ATX connector where as G41 combo has 4 pin input.
What is culprit ? Is it processor ?
HP DV6-3057TX|Dell Mini 12
955BE @ 3.5GHz|Gigabyte 880GM-USB3|Kingston SSDNow V100 64GB|Seasonic S12II 620W|HD6970 aka unlocked Sapphire HD6950 2GB Dirt3 edition |NZXT Gamma|Cooler Master Hyper 212 EVO|Corsair Vengeance 8GB 1600MHz |WD 500GB+ 1TB|Razor Abyssus|Dell ST2220L
Apple iPod Touch 4G 32GB |Samsung Galaxy Ace
Last edited by vyral_143; 10-01-2012 at 10:38 PM. Reason: Sentence correction needed.
vyral_143 is online now   Reply With Quote
Old 11-01-2012, 07:47 AM   #2 (permalink)
Default Re: No display from system
were you able to use any other monitor before this dell? if you have done it before would recommend you to refit the processor. have a steady hand and dont apply too much force on processor fan screws.
Old 11-01-2012, 10:27 AM   #3 (permalink)
Earlier it was working with my Samsung 19" monitor. Once, with system 1 and Dell display, I was able to run system. I was setting date in BIOS and it got hanged. On hard reseting it showed me some CMOS checksum error...bla bla
After which this saga continues.
Old 11-01-2012, 12:57 PM   #4 (permalink)
my precious
Gollum's Avatar
Originally Posted by vyral_143 View Post
Hi,
System 1:
Intel C2D E6550
Gigabyte G41 Combo
Corsair VX450
System 2:
Gigabyte 880GM USB3
Seasonic 620W
system2:
bios settings are set to first priority as discrete graphics
or
set to fixed discrete graphics and no priority
also your system is either dirty or... so re-seating the ram module will do the trick.
system1: motherboard is faulty, replace.
if your hdd light does not flicker and keyboard is unresponsive mobo faulty
troubleshooting steps without the discrete graphics card. Also try to reset the CMOS by removing the RTC Battery.
1: press multiple keys on kb simultaneously, check for beeps. if no beeps, mobo faulty.
2: go online and get diagnostics and error codes for your specific mobo, maybe it does not give beeps but flashes LED's
Gollum is online now   Reply With Quote
Old 11-01-2012, 02:11 PM   #5 (permalink)
I replaced mobo and checked at service center. Their monitor was getting display. After coming to home for one time monitor was getting display.
Keyboard LED is not lighting.
Old 11-01-2012, 08:27 PM   #6 (permalink)
i have a feeling the power supply is acting funny. use an alternate one. keyboard led wasnt lighting? really strange.
Old 12-01-2012, 09:01 PM   #7 (permalink)
my precious
Gollum's Avatar
try without any addon card and hdd and cd/dvd
try swapping the psu also, if it still does not work
its the motherboard.
also, which cabinet are u using? do you have riser screws installed?
one main point, do you have proper earthing?
Old 12-01-2012, 10:07 PM   #8 (permalink)
I guess PSU testing is now remaining.
Motherboard was giving proper display at service centre and once at home too. Dunn know what happened then. Once I could see an error - CMOS checksum bla bla.
Earthing is proper.
Old 13-01-2012, 09:38 AM   #9 (permalink)
my precious
Gollum's Avatar
check the boss setting again with and without the graphics card.
Old 16-01-2012, 10:45 PM   #10 (permalink)
Update:
System 2 working fine now.
System 1 still giving lot of trouble
Tried connecting Corsair VX450 to System 2, it ran, hence Corsair VX450 is working fine
Corsair XMS3 2x2GB and XFX 8800GT work fine on System 2, hence they are also working fine.
I was suspecting my 2x1GB DDR2 800MHz to be culprit. But when i put Corsair Corsair XMS3 2x2GB in Gigabyte G41 Combo, still no display. Hence it might possible that DDR2 RAMs are also working fine - will prefer confirming on some ones else's PC.
Also couple of things noted
1. whenever i press button of my UPS, all three keyboard light would blink once.
2. I put GFX card on G41 Combo, dunn give power to it, connect VGA cable to motherboard and try to bot. Result -> a long continuous beep.
Is mobo gone again ?
I had brought it checked from service center.
Old 18-01-2012, 10:23 AM   #11 (permalink)
Anyone ?
Old 18-01-2012, 02:49 PM   #12 (permalink)
since you have tried almost anything so try this also.get a new cmos battery for ~35 & replace the old one on the problem mobo.boot & check all bios options especially graphics adapter priority order.
Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
whitestar_999 is offline   Reply With Quote
Old 22-01-2012, 07:37 PM   #13 (permalink)
Anything more to test any one ?
Old 22-01-2012, 07:47 PM   #14 (permalink)
knocking on heavens door
sumonpathak's Avatar
try a bios reflash...blindflash...
i5 2500k @ 4GHZ|E7500 @ 3.80GHZ|Athlon II X3 425 @ 3.68GHZ|Phenom II X4 965 @ 4.21GHZ|FX-8150 @ 5GHZ
P8Z68 Deluxe|Z68X-UD4|G31M-ES2L|Crosshair V Formula | 880GM-USB3 | M4A785T-M
HD 6870|HD 5450 2GB|Geforce 9400GT 1GB DDR2|Geforce 8400GS 512 MB DDR2
Corsair Value Select DDR3 review
A guide to Benchmarking world
FX 8150 Review
sumonpathak is offline   Reply With Quote
Old 22-01-2012, 11:37 PM   #15 (permalink)
^ how to ?
Old 22-01-2012, 11:39 PM   #16 (permalink)
you should be able to do this from your dvd...for the exact specific see your manual...
i will link you with sources when i find something similar...
chek this...
replace floppy with a pen drive...
format it with fat16 file system
http://www.biosman.com/biosrecovery.html
Originally Posted by Biosman
1. Create a bootable floppy diskette
2. Copy the BIOS file and flash utility to the diskette
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
links on how to create a bootable bios stick
http://www.sevenforums.com/tutorials...ve-create.html
FX 8150 Review
Old 23-01-2012, 10:22 AM   #17 (permalink)
^^Thanks Sumon. Process stated by you does not require display to work ?
Old 23-01-2012, 11:51 AM   #18 (permalink)
for blind-flash no....
FX 8150 Review
Old 25-01-2012, 02:24 PM   #19 (permalink)
Ohk.
So without display BIOS flashing, feels different.
I will it a shot tomorrow as its holiday.
Old 25-01-2012, 03:33 PM   #20 (permalink)
good luck
read up before u start anything...
FX 8150 Review
- by kool
