Old 10-01-2012, 09:11 PM   #1 (permalink)
Default +12V voltages varying greatly with different software
Hi everyone. i was checking the +12V readings of my system today. i was pretty surprised by the various data that i got from different softwares. e.g.
hwmonitor(1.05) - 10.43
hwmonitor(1.12) - 8.25
everest(5.01) - 12.41
i checked with each software multiple times, got the same reading in each case.
is it natural for these softwares to display such variations in readings?
p.s. - yes, i could take the reading with a multimeter, but that's for later.
sam1 is offline   Reply With Quote
Old 11-01-2012, 05:03 AM   #2 (permalink)
Fast 'N' Furious
topgear's Avatar
Default Re: +12V voltages varying greatly with different software
if you pc is running stable then do put much attention to these voltage readings and yes, HW monitoring app can display such variations in readings - it's normal and I recommend you to use HWinfo
ToPsPeEeD = FaSt BuT StEaDy
Old 11-01-2012, 05:49 AM   #3 (permalink)
Check with AIDA64 or in the BIOS.
Old 11-01-2012, 02:50 PM   #4 (permalink)
avinandan012's Avatar
i would suggest use the BIOS or a mutimeter
Phenom II x4 955 @ stock with ASUS M3A78-EM (after upgrade BIOS(2701) no AUDIO in Win 7 :x) 4GB DDR2 Transcend, 1TB+2TB, SAMSUNG ext DVD writer, ASUS lightscribe internal DVD Writer, Intex 2.1 sound, NZXT Gamma, CM Excalibur, Corsair TX 850 :twisted:, CM Extreme PowerPlus 600
PHILIPS SHM 1900
Lenovo z570
Steelseries Siberia USB soundcard
avinandan012 is offline   Reply With Quote
Old 11-01-2012, 03:57 PM   #5 (permalink)
CA50's Avatar
The exact reading comes from a multimeter, you can read from the BIOS as well
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 14-01-2012, 10:03 AM   #6 (permalink)
thnx for ur suggestions everyone.
- by kool
