Old 09-01-2012, 09:47 PM   #1 (permalink)
Constructed New Rig..!!
Default System freezes/hangs in ~6 mins
Hi,
Recently I assembled a system
AMD Phenom II X4 955BE
Gigabyte 880GM-USB3
Cooler Master Hyper 212 Evo using Arctic Silver 5
Corsair XMS3 2x2GB 1600MHz
WD 1TB Green and 500GB
XFX 8800GT 512MB
Seasonic S12II 620W
Kingston SSDNow V100 64GB
NZXT Gamma
Installation of windows 7 was breeze, completed in just 11 mins . Later I installed drivers/utilities from supplied Gigabyte Disc.
After which system gets freeze-d in ~6 mins. Hard reset remains the only option. 6 mins is time frame from moment i press power button on my case till system hangs/freezes. Last time toh i kept my system idle still it got hanged.
I have taken photos of HWMonitor at time of freezing.
What might be causing this ?
HP DV6-3057TX|Dell Mini 12
955BE @ 3.5GHz|Gigabyte 880GM-USB3|Kingston SSDNow V100 64GB|Seasonic S12II 620W|HD6970 aka unlocked Sapphire HD6950 2GB Dirt3 edition |NZXT Gamma|Cooler Master Hyper 212 EVO|Corsair Vengeance 8GB 1600MHz |WD 500GB+ 1TB|Razor Abyssus|Dell ST2220L
Apple iPod Touch 4G 32GB |Samsung Galaxy Ace
vyral_143 is online now   Reply With Quote
Old 09-01-2012, 10:20 PM   #2 (permalink)
Default Re: System freezes/hangs in ~6 mins
never used hwmonitor before but the value of 3.97v(+12V min under voltages)looks unusual to me.the voltage on +12V rail should never be below 12v as i understand it & certainly not this low.similar low voltage is reported in your 2nd pic too(5.50v).
Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
whitestar_999 is offline   Reply With Quote
Old 09-01-2012, 10:40 PM   #3 (permalink)
^^ yup. it should be 12.**V all the time.
have you tried updating the drivers?
Old 09-01-2012, 10:47 PM   #4 (permalink)
Nah i have not tried updating drivers. I have installed one which were in Disc.
Also i don't think i will be able to because in process of updating my system will cross threshold of 6 mins.
Old 09-01-2012, 10:55 PM   #5 (permalink)
try safe mode & check what happens. do you have access to linux live CD? if yes, try using it.
Old 09-01-2012, 11:05 PM   #6 (permalink)
check with another power supply & hwmonitor.
Old 09-01-2012, 11:32 PM   #7 (permalink)
Super Moderator
asingh's Avatar
Check the RAM, using MEMTEST- DOS version.
asingh is online now   Reply With Quote
Old 10-01-2012, 07:15 AM   #8 (permalink)
Will try linux thing, SMPS and memtest.
My SMPS is brand new. Hope no RMA scene for it.
Also I have installed OS on SSD with AHCI mode enabled. What is TRIM ?
Old 10-01-2012, 12:38 PM   #9 (permalink)
a TRIM command allows an operating system to inform a SSD which blocks of data are no longer considered in use and can be wiped internally.
from wikipedia. TRIM is not supported by Windows XP.
Old 10-01-2012, 01:12 PM   #10 (permalink)
Update: My younger bro re-installed Win 7 without listening to me
But good new is that its raw Win 7, without any drivers or anything and for 20-25 mins it did not hang or freeze.
I will test by myself wih HWMonitor when I return to home in evening.
Old 10-01-2012, 03:07 PM   #11 (permalink)
avinandan012's Avatar
ATX specifiaction allows -10% to +10% on the 12V rail.
Seeing that HWmonitor screenshot it is a clear case of PSU is not working properly
Phenom II x4 955 @ stock with ASUS M3A78-EM (after upgrade BIOS(2701) no AUDIO in Win 7 :x) 4GB DDR2 Transcend, 1TB+2TB, SAMSUNG ext DVD writer, ASUS lightscribe internal DVD Writer, Intex 2.1 sound, NZXT Gamma, CM Excalibur, Corsair TX 850 :twisted:, CM Extreme PowerPlus 600
PHILIPS SHM 1900
Lenovo z570
Steelseries Siberia USB soundcard
avinandan012 is offline   Reply With Quote
Old 10-01-2012, 03:14 PM   #12 (permalink)
that's why i used should(& not must) not fall below 12v
Old 10-01-2012, 07:25 PM   #13 (permalink)
That 12V values are applicable for only +12V or -12V also ?
Because now I am getting constantly 12.35V on +12V though -10.69V or -7.36on -12V.
- by kool
