Old 06-01-2012, 07:27 PM   #1 (permalink)
THE CHOSEN ONE
Blue Ripazah's Avatar
Angry what is the problem???
hi i inserted a DVD in the drive and then suddenly the computer freeze and it showed this message ...i don't why is this saying as hardware failure moreover after the restart it didn't showed DVD drive ...i opened the case and inserted the power cable again...please help me i am having a Sony DVD ROM.....
Blue Ripazah is offline   Reply With Quote
Old 06-01-2012, 10:51 PM   #2 (permalink)
BMG ftw!!
d6bmg's Avatar
Default Re: what is the problem???
Check the dump file.
d6bmg is offline   Reply With Quote
Old 06-01-2012, 11:05 PM   #3 (permalink)
THE CHOSEN ONE
where can i find the dump file
Intel i3 540|| Gigabyte H55M D2H || 2x2gb corsair value Ram|| :doublethumb: Saphire Hd 6670 :doublethumb:||:mrgreen: Samsung B2230 :mrgreen: || 500 GB Seagate || 80 Gb Seagate|| IBall 7299||Gsm Insipre 500 watt :banghead:||Creative A 300 with philips speakers ||Sony dvd rw|| Samsung Galaxy Ace 8-)||
Old 06-01-2012, 11:07 PM   #4 (permalink)
disable autorun on all drives/dvd drive.
in windows 7 control panel-->autorun.
in xp(do this before inserting any cd/dvd):
Open Windows Explorer by pressing the Windows + "e" key.
Right-click the desired CD-ROM and select Properties from the menu.
Select the AutoPlay tab.
Select each item from the pulldown list and for the Action to perform, select "Take no action" to disable autorun, or pick the apporpriate action to take if enabling autorun.
Select OK.
after disabling autorun try again with same dvd & a different cd/dvd to confirm if the problem is with dvd or not.if problem is not with the dvd then recheck all drive connections & try with different sata & power cable.
Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?
whitestar_999 is offline   Reply With Quote
Old 07-01-2012, 10:41 AM   #5 (permalink)
Fullbring
Zangetsu's Avatar
Eventviewer might help...
type eventvwr in run dialog box & check for errors
Old 07-01-2012, 12:18 PM   #6 (permalink)
CA50's Avatar
@Sonil.luthra, is the ODD displayed under BIOS ??
Do the lights on the ODD lit up??
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 07-01-2012, 12:20 PM   #7 (permalink)
check for driver updates and software updates the most common thing for Bluescreen
check ur HDD for smart errors and perform a CHKDSK f4 BSOD is usually bcoz of Bad sectors in HDD or SMART Failure
Athlon II X4 640||GigaByte 78LMT-S2P||Corsair 4GB DDR3 1333Mhz+ 2GB EVM DDR3 1333Mhz||VIP 400watts PSU||Sapphire 5670 930/1020:P|| Philips 107E5 1280x1024 17''CRT|| Zebronics Bijli mod
http://www.hardfolding.com/fhtag.php...451114/1/4.png
Tarun is offline   Reply With Quote
Old 07-01-2012, 02:05 PM   #8 (permalink)
THE CHOSEN ONE
yes my hdd is faulty ill be sending it for rma on monday ...
Old 21-01-2012, 09:49 PM   #9 (permalink)
THE CHOSEN ONE
it happened again ...i installed another hdd from my friend the same thing happened again ...what might be faulty ....does anyone know abt this error
Old 21-01-2012, 10:46 PM   #10 (permalink)
Off for a while.
dashing.sujay's Avatar
If you can reassemble all your parts, do that (remember your faulty SATA cable/port problem?). Then do a chkdsk. I guess everything should be fine by then.
Sony Vaio CB35-> i5-2430M | 6630M | 4GB | 1080p | Backlit Keyboard
Read before asking / messaging any moderator for any query: FAQ + answers for new members
Drop Box: Get 500MB free
dashing.sujay is offline   Reply With Quote
Old 21-01-2012, 10:54 PM   #11 (permalink)
The Sorcerer's Avatar
What's your system config??
Hardware BBQ
The Sorcerer is online now   Reply With Quote
Old 22-01-2012, 12:56 AM   #12 (permalink)
cheack ur PSU and the DVD drive then
Old 22-01-2012, 01:01 AM   #13 (permalink)
THE CHOSEN ONE
will do it for sure but i cannot reassemble cpu and mobo ...but for the rest i can ...
its
core i3 540
gigabyte h55md2h
2gb corsair
500gb seagate (currently in RMA)
psu ...might be an el cheapo ..but i think it is a good quality el cheapo..i got it dor 850rs from costtocost delhi...
Old 22-01-2012, 01:02 AM   #14 (permalink)
Off for a while.
^That would be enough for preliminary test.
Old 22-01-2012, 01:08 AM   #15 (permalink)
THE CHOSEN ONE
morever there is a bad news i accidently damaged one sata port on my mobo ......
what shud i do now ...
Old 22-01-2012, 01:18 AM   #16 (permalink)
Off for a while.
^Nothing can be done except to take it to local technician which is too risky and should be only done when the damaged one is last.
Old 22-01-2012, 01:21 AM   #17 (permalink)
THE CHOSEN ONE
but the rest of the ports are working fine
Old 22-01-2012, 01:22 AM   #18 (permalink)
Off for a while.
^Then why worry?
Old 22-01-2012, 01:28 AM   #19 (permalink)
THE CHOSEN ONE
i think now it is out of warranty......and can plz tell me ho many years does gigabyte provides warranty ..
Old 22-01-2012, 02:38 AM   #20 (permalink)
Electronic.
Neuron's Avatar
You won't get warranty coverage for damages caused by improper handling.
I don't always make sense,but when I do,I don't.
Neuron is offline   Reply With Quote
Old 31-01-2012, 09:56 PM   #21 (permalink)
THE CHOSEN ONE
Hdd back from RMA....but tha error in the image is still there ....can anybody help me...what shud i do now.....please ....need serious help ...
Old 31-01-2012, 09:59 PM   #22 (permalink)
Rubik's Uncle!!
Charan's Avatar
did you check by replacing your DVD drive with one from any of your friends?
Charan is offline   Reply With Quote
Old 31-01-2012, 10:13 PM   #23 (permalink)
THE CHOSEN ONE
Ohhhkk will do it...
Are sure thats the main issue
Old 31-01-2012, 10:18 PM   #24 (permalink)
Rubik's Uncle!!
Charan's Avatar
cant say thats the main issue, but it seems to be the culprit, also try to use other SATA ports.
Old 01-02-2012, 12:22 AM   #25 (permalink)
THE CHOSEN ONE
The dvd drive is working fine when i am running it via ubuntu live usb
but now it is performing very slow and i am unable to install windows...any gueses what might be the problem is
please experts help me ill be very grateful ...
Old 01-02-2012, 12:25 AM   #26 (permalink)
Super Moderator
asingh's Avatar
MEMTEST the ram.
asingh is online now   Reply With Quote
Old 01-02-2012, 12:29 AM   #27 (permalink)
run chkdsk again to verify the hard disk you are using.
Old 01-02-2012, 12:36 AM   #28 (permalink)
THE CHOSEN ONE
Did that ...nothing found ...was perfect
Old 01-02-2012, 08:55 AM   #29 (permalink)
try change ur PSU once if u can
Old 01-02-2012, 09:00 AM   #30 (permalink)
Rubik's Uncle!!
Charan's Avatar
As I said before, please change the drive once and check. as your current problem's source is the DVD Drive, you should check by replacing it with another test drive. Apart from that try swapping the SATA Ports for your drive and HDD.
- by kool
