Old 01-02-2012, 10:54 AM   #31 (permalink)
THE CHOSEN ONE
Blue Ripazah's Avatar
Originally Posted by Charan View Post
As I said before, please change the drive once and check. as your current problem's source is the DVD Drive, you should check by replacing it with another test drive. Apart from that try swapping the SATA Ports for your drive and HDD.
Will try to arrange a dvd drive many of my friends are using a loptop only so ...a bit hard to find a dvd drive ...and did the slot changing procedure....is there any software from wich i can make windows xp bootable flash drive
...i m running ubuntu live i need a software that will run on ubuntu to make a booyable usb for installing windows...
Intel i3 540|| Gigabyte H55M D2H || 2x2gb corsair value Ram|| :doublethumb: Saphire Hd 6670 :doublethumb:||:mrgreen: Samsung B2230 :mrgreen: || 500 GB Seagate || 80 Gb Seagate|| IBall 7299||Gsm Insipre 500 watt :banghead:||Creative A 300 with philips speakers ||Sony dvd rw|| Samsung Galaxy Ace 8-)||
Blue Ripazah is offline   Reply With Quote
Old 01-02-2012, 12:40 PM   #32 (permalink)
Rubik's Uncle!!
Charan's Avatar
Default Re: what is the problem???
Windows XP? can I know the reason why you want to stick to windows XP and not the latest version i.e., Win 7
im not sure about tools available in Ubuntu to create Bootable XP Flash Drive , but if you can get hold of some of your friends laptop/pc then you can use this guide How to Create a Bootable XP Flash Drive | eHow.com
I would still recommend you to go for Win 7
EDIT: Another link for information on creating Win7 Bootable USB Drive Microsoft releases Win 7 USB / DVD download tool for easy install on netbooks without DVD drive
EDIT: Installing Windows 7 from a pen drive
Charan is offline   Reply With Quote
Old 01-02-2012, 01:32 PM   #33 (permalink)
THE CHOSEN ONE
I also want to run windows 7....but my father has to use the pc for running tally 7.2 for his accounting work
And morever the issue is solved it was that psu which was creating problems...will never buy that stuff ...ill be getting it replaced as it is having another 3 month replacement warranty left..and will sell it rightaway...the problem was with sata power connectors
Old 01-02-2012, 02:24 PM   #34 (permalink)
Rubik's Uncle!!
Charan's Avatar
Great!! so you finally found the problem. Tarun's guess was right
BTW go for a good PSU now. check this section for more details Power supply / Cabinets / Mods - Digit Technology Discussion Forum
Old 02-02-2012, 11:44 AM   #35 (permalink)
Undead!!!
Sujeet's Avatar
morever there is a bad news i accidently damaged one sata port on my mobo ......
what shud i do now ...
what kind of damage???
Hollywood Undead
I want to teach you to live the truth, to reveal the light within your own soul-Swami Vivekanand.
Greatest Troll of Millennium.Here
Sujeet is offline   Reply With Quote
Old 02-02-2012, 02:26 PM   #36 (permalink)
THE CHOSEN ONE
One of the sata port came out of the board
- by kool
