Re: Monitor Power Cord issue
there are various size available in 3 pin connectors, but it will be more better if you go out in market with that cord and buy the connector for the same,
as it will ensure that have got what you needed...
buying online is a bit risk in terms of compatibility with the cord,as i think it...
Don't you think so?
or you may look for if there is any info given on its manual or website, or you can google the problem like - 3 pin connector for benq (model no.) monitor power cord... but chances are rare...
intel core2duo e7400 2.80GHz, intel DG41TY, Kingston 3 GB DDR2 800MHz, 1TB seagette SATA, samsung 22x DVD-RW, sapphire AMD RADEON HD 6870 1 GB GDDR5, CM xtremepower 600W, logitech z506, samsung BX2031N, HCL keyboard, microtek 600VA UPS, Nokia Xpressmusic 5320
