Old 03-01-2012, 06:45 PM   #1 (permalink)
Unhappy External Harddrive not working
I bought an external hard drive from Amazon and got it through a friend. It's a Seagate FreeAgent GoFlex Desk 2 TB USB 3.0 External Hard Drive STAC2000106. It's new and the drive wont even power up and the Accel service centre in Coimbatore where i hail from has told me there is no way they can service the equipment even though i was ready to pay for it.
padfootara is offline   Reply With Quote
Old 03-01-2012, 08:13 PM   #2 (permalink)
CA50's Avatar
Default Re: External Harddrive not working
Since you have bought it from amazon you can mail them about this.
And are you sure that you have attached all the cable properly
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 03-01-2012, 10:04 PM   #3 (permalink)
BMG ftw!!
d6bmg's Avatar
HDD bought from amazon falls directly under their own RMA service. Mail them & you will have to send it to them (from where you have bought it)
d6bmg is offline   Reply With Quote
Old 04-01-2012, 07:56 PM   #4 (permalink)
Can you give me a list of possible problems? Please!
Old 04-01-2012, 09:48 PM   #5 (permalink)
BMG ftw!!
d6bmg's Avatar
^^ What? I didn't get your post.
Old 04-01-2012, 10:06 PM   #6 (permalink)
Would it not be beneficial for the "OP" if he/she registers the product on Seagate's website first and then contacts their customer support helpline?
The customer service should advice the "OP" appropriately with regard to RMA.
let us all see the "i" in the "u".
insaneYLN is offline   Reply With Quote
Old 05-01-2012, 09:06 PM   #7 (permalink)
I have posted a request in the Amazon forum. With which id should i contact them?
- by kool
