Old 03-01-2012, 12:04 PM   #1 (permalink)
marvelousprashant's Avatar
Default Unknown device in Device Manager
Hello Guys. Just noticed I've an Unknown Device in Device Manager. Dont know what it is. "Update driver" fails.
Read on some website that this may be generated by some software. So I restarted my laptop in safe mode. The problem was still there. What to do?
HP Pavilion dv6-6017tx
i7-2630QM, 4GB RAM, 1GB Radeon HD 6770M. Very happy with this laptop because it makes an Apple fanboy go NUTS :shock: :razz::razz::razz::razz::razz:
Twitter : marvelprash
marvelousprashant is online now   Reply With Quote
Old 03-01-2012, 12:58 PM   #2 (permalink)
CA50's Avatar
Default Re: Unknown device in Device Manager
^ Is this from a laptop? Try installing from the driver disc that you got with the laptop
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
CA50 is offline   Reply With Quote
Old 03-01-2012, 01:00 PM   #3 (permalink)
Fullbring
Zangetsu's Avatar
the unknown device may be due to corrupt driver files...
did u used some external devices (plug&play)?
Old 03-01-2012, 01:06 PM   #4 (permalink)
Still Shining!
Lucky_star's Avatar
I had an unknown device on my 6121tx when I had wiped the HDD and custom installed Win 7. I went on to install almost all the drivers in the SWSetup folder again, installed all the updated ones on top of it, and after a couple of Windows updates and system restarts, it went away.
Nokia N86 8MP
Lucky_star is offline   Reply With Quote
Old 03-01-2012, 01:06 PM   #5 (permalink)
yes its a laptop. Did not get any driver discs but tried a few drivers I had downloaded from support page. Did not help.
Old 03-01-2012, 01:07 PM   #6 (permalink)
BMG ftw!!
d6bmg's Avatar
Is there any part of your laptop which supposed to work & not working?
Test that. There is no other way of telling what exactly is that.
d6bmg is offline   Reply With Quote
Old 03-01-2012, 01:09 PM   #7 (permalink)
yes. My old N86. Its micro USB port is broken so sometimes laptop fails to recognize it. How do i remove this from device manager?
Everything I know in this laptop is working
Old 03-01-2012, 01:10 PM   #8 (permalink)
BMG ftw!!
d6bmg's Avatar
To remove it, just disable that hardware from the device manager.
Old 03-01-2012, 01:13 PM   #9 (permalink)
CA50's Avatar
@marvelousprashant, you can download all the drivers related to the laptop, and install those.
Sometimes there are some hardware like card reader, etc. for which you will have to install the drivers
| Nokia 2700c |
Old 03-01-2012, 01:15 PM   #10 (permalink)
Fullbring
Zangetsu's Avatar
@marvelousprashant: always use CCleaner for removing junk files & solve driver problems...
Old 03-01-2012, 01:16 PM   #11 (permalink)
abhidev's Avatar
try using drivereasy software to download missing drivers on you laptaop
Core 2 duo E4500 2.2gHz , ASUS P5GCMX , 3GB Transcend , Corsair VX 550w, MSI R5770 HAWK Edition 1GB, CM HAF-922, LG W2243T 21.5" LCD, I-Ball Baton
abhidev is offline   Reply With Quote
Old 03-01-2012, 01:21 PM   #12 (permalink)
Thanks everyone. Ive uninstalled it. I hope it wont create problems. I've use CC cleaner and various driver update softwares before. Did not help.
Old 03-01-2012, 01:23 PM   #13 (permalink)
Fullbring
Zangetsu's Avatar
yup...remember to run CCleaner Scan on registry whenver u uninstall softwares.
also try TuneUp 2012...
Old 03-01-2012, 01:26 PM   #14 (permalink)
BMG ftw!!
d6bmg's Avatar
^^ Uninstalled?? what have you uninstalled?
Old 03-01-2012, 01:29 PM   #15 (permalink)
the unknown device
Old 03-01-2012, 01:33 PM   #16 (permalink)
mithun_mrg's Avatar
^^ try windows update even if u uninstall it i think it will come back once u reboot
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
mithun_mrg is offline   Reply With Quote
Old 03-01-2012, 01:35 PM   #17 (permalink)
nothing in windows update
Old 03-01-2012, 03:02 PM   #18 (permalink)
copy the the hardware id from the properties of the unknown device and google it.
Toshiba M500|| NZXT Gamma Cabinet||Dell IN2030M||Canon Pixma MP287||Nokia N73|| Nokia X1-01||Ipod Shuffle||
bibinjohn is offline   Reply With Quote
- by kool
