30-12-2011, 12:52 PM
Sync out of Range
Hi
PC specs:
ASUS M/B with on board graphics. HD is partitoned in to 3 parts with XP-SP3, Win 7 and Ubuntu on different partitons. Other OSs works well, but sometimes the XP shows the Sync out of Range error; which I took a photo and u/l, and the image is attached.
When I reboot 1 to 3 times it starts normally, this is happening only sometimes, other times it starts normally. Please tell me what could be the problem?
30-12-2011, 01:06 PM
Re: Sync out of Range
install the proper vga/gpu driver post the model of the MB so that we can help
Corei3-530@4.5,MSI P55-GD65,Gskill 4G,Coolit ALC,Tagan 500W,XFX 6850@1000/1200,MX 518,Razer Abyssus,Avermedia Pcie TV,Audigy,VS3251,Transcend MP330 8Gb, PL11, PMX 60,PSP 3000 , Galaxy 551,Nokia C1-02.
30-12-2011, 01:12 PM
That error usually appears when the output of the system is higher then the maximum capacity of the monitor.
Try lowering the video resolution and the refresh rate
| A Bit IP35-Pro | E8400 | GTS250 | Gskill 2x2GB | 1.9 TB | CM EP+ 460W | 2x DVD-RW|
| Nokia 2700c |
30-12-2011, 01:26 PM
You have made resolution too high. Lowering it will fix the problem
30-12-2011, 04:39 PM
thanks for all your replies.
hi mithun The MB model is ASUS P5KPL-VM.
As per lowering the resolution and refresh rate -- it works other times perfectly ok without changing anything!
30-12-2011, 04:44 PM
30-12-2011, 06:15 PM
I'm a Wannabe Hacker
^ +1 keep your drivers updated.
Lowering the resolution and maintaining the right refresh rate fixes the problem most of the time.
Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning. - Rich Cook
30-12-2011, 08:17 PM
BMG ftw!!
Start OS in safe mode & decrease resolution & then starting your PC in normal mode install & update drivers.
10-01-2012, 04:50 PM
hi
I d/l the file mentioned by mithun and installed, also reduced the resolution, I observed for few days no problem, Again today the same scree as shown above? Please tell me any other solution?
10-01-2012, 05:23 PM
Electronic.
Originally Posted by gramesh
hi
Download the updated driver for your monitor not your graphics card.I too had this problem.I used to get sync out of range message when booting Windows 7,in rare cases.I installed the updated driver for my monitor and it worked.
I don't always make sense,but when I do,I don't.
10-01-2012, 10:47 PM
Thanks Neuron, I d/l the monitor driver, installed, will come back after watching it for 2-3 days.
